I don’t see that process too.I'm getting:
Code:kill: you need to specify whom to kill
I'm not doing something right, I guess. I have a list of names and addresses here... if this is what the router is asking for...![]()
Then it’s not the solution to the problem you have. Keep searching…I'm getting:
Are you trying to use any Gaming features like Gear Accelerator?RT-AC86U here
I noticed my QoS type keeps switching back to Adaptive by itself after I set it to Cake. (This is not happen in previous stable version)
Networkmap calls asusdiscovery when necessary. It shouldn’t be running all the time. If it gets stuck, it might prevent networkmap from scanning next time.Does asusdiscovery handle the client list or some aspect of it?
I don’t know if my information is 100% accurate. There’s a lot of educated guessing necessary when dealing with the closed source stuff.
The stuck wired clients finally disappear from Client List after full 24h - the IP lease renewal time. It's working...![]()
Question: Why haven't users moved to the 386.9 Beta?
I haven't experienced any anomalies, nor read of any issues.
I don't know. Even a recompile by Asus when they build the GPL will generate a different binary blob, I have no way of knowing if there was any code or calibration table changes.@RMerlin can you tell if the wifi radio drivers are updated in 386_50757?
The version won't change if Asus just applies patches or make changes to the calibration tables.Unless there is secret sauce in the compilation process - the underlying driver versions appear to be exactly the same for the RT-AC86U.
ok. Perhaps if asusdiscovery gets stuck, it remains running? I'll keep an eye on it and see if my weekly kill script allows the client list to remain accurate.
Welcome To SNBForums
