amtm amtm 3.1.9 - the Asuswrt-Merlin Terminal Menu
Do you know why this font is installed in your Entware?
opkg list-installed | grep ^deja
opkg whatdepends dejavu-fonts-ttf-DejaVuSerif-Italic
If there’s no reason for it, try to remove it with opkg remove dejavu-fonts-ttf-DejaVuSerif-Italic
I think its a dependency of vnstati, at least I seem to recall seeing it when working on dn-vnstat
From Jack's append, removed vnstati, but the font file didn't remove. Then followed your suggestion using this command line... "opkg remove dejavu-fonts-ttf-DejaVuSerif-Italic" but appears a 'Force' parameter required? The screen shots showing my steps. Thanks guys, appreciated.
Maybe just easier to reinstall it.
opkg --force-reinstall install dejavu-fonts-ttf-DejaVuSerif-Italic
Using that script, the reinstall of font worked (messaging doing it wasn't conclusive to me). Vnstat reinstalled. AMTM option 'U' now worked without error. Thanks Dave!, saved a USB flash-drive format and re-install of packages.
