amtm amtm 4.9 - the Asuswrt-Merlin Terminal Menu, June 30, 2024 (locked thread)
Script update notification mod:
After a router reboot, the Cron job is generated that way, which obviously doesn't run:
10 7 * * Sun /bin/sh /sc_update.mod -run #amtm_ScriptsUpdateNotification#
However, when manually removing/reinstalling the mod, it is generated correctly:
10 7 * * Sun /bin/sh /jffs/addons/amtm/sc_update.mod -run #amtm_ScriptsUpdateNotification#
Thanks for reporting.
amtm 4.3 is now available
- Adds support for 8 MerlinAU - The Ultimate Firmware Auto-Updater by @ExtremeFiretop, with major contribution from @Martinski. Welcome to amtm! See https://www.snbforums.com/threads/i...e-ultimate-firmware-auto-updater-addon.88577/
- Adds support for vp VPNMON-R3 - Monitor WAN/Dual-WAN/VPN Health & Reset Multiple VPN Connections by @Viktor Jaep. See https://www.snbforums.com/forums/asuswrt-merlin-addons.60/?prefix_id=36
Also, thanks to orionstar on GitHub for being such a good sport and make your own version of the *.mod file!
- Sunsetts VPNMON-R2 (command is now vp2) by @Viktor Jaep, it can no longer be installed through amtm.
- amtm feels and is faster in building the list of installed scripts, notably on older routers.
- Added extra check for entware folder deletion when removing Entware.
- Removes support for pixelserv-tls "pixelserv-tls CA for WebUI" feature, one can still run the command manually by entering the following into the SSH terminal: sh -c "$(wget -qO - https://diversion.ch/scripts/config-webgui.sh)"
- The dc Disk check is now run directly by the disk_check.mod file instead of a separate file.
- Reworked check if email settings are complete.
- Correctly adds sc scripts update notification cron job when (re)booting. Thanks to @maghuro for reporting.
- Now returns exact Asuswrt-Merlin firmware version number in header. Thanks to @Martinski (Martinski4GitHub on GitHub) for being persistent.
- Revamped the header content and added static current router timestamp.
- Now hides already installed scripts in the i available scripts screen for brevity.
- Does no longer remove empty lines in /jffs/scripts files. Thanks to Max33Verstappen on Github for being persistent.
- Rearranged amtm options for brevity.
- Replaced many multi-line echo commands with printf.
Use u to update to this latest version.
Thanks for the major update. I appreciate your continued support.
Anyone know what would be the process to request CAKEQOS-MERLIN v2.1.2 add-on script be added to amtm?
Updated... So far so good.
Thanks @thelonelycoder !
I was wondering why it says "setup" email settings in your screen if amtm deems it installed. It should say "open" instead.
I had to smile at my own "cover almost every possible outcome" mentality.
You have not set your password yet, that's why.
I just updated and I find a couple of errors.
One error is related to an old script that stopped being supported by amtm, nsrum.
I tried to removed this old script but I didn’t find the proper method.
The error is “! Module nsrum.mod is not an amtm file.”
The second error refers to “! using fallback server diversion.ch” and I don’t know what exactly means or how to solve it, because I didn’t find this option under the diversion settings.
Enter uu into amtm, it will remove it.
Yep...
I was running VPMON-R3 latest version and after updating AMTM the option now shows in AMTM but I can't get it to run VPMON from AMTM.
Still have to exit AMTM and start VPMON-R3 with "sh /jffs/scripts/vpnmon-r3.sh" at command line. Tried updating entware dependencies and still won't start.
I see, your v3 was manually installed. Let me get a fix out. Won’t take long.
There, that should fix someone else's blunder.
Use uu to force update amtm.
An amtm update is available, no version change.
What's fixed?
- Fixes VPMON-R3 not starting in amtm when it was manually installed before amtm supported it.
Use u to update
Smooth update 4.2 -> 4.3 - thank you!
What's fixed?
Use u to update
Thanks. The change in amtm now lets VPMON-R3 start from within amtm when it had previously been installed manually.
Showing available scripts (i) is quite snappy now!
We might have discussed this in the past - @thelonelycoder since the email function in terms of setup works so well in AMTM, it would be nice to have some callable script to send an email.
Something like:
amtmail foo@bar.com "This is a test subject line" afiletosend
I just had a weird thing happen - nearly all of my cronjobs disappeared.
I posted another thread about it, but right after posting I realised one change I made was to update amtm earlier today.
It's never happened before - could there be any connection?
The other thread is here...
Something like:
That’s exactly what I pondered to do about two or so years ago. Time to revisit that idea.
