Jaime Alvarez
Isn't .ch the Swiss TLD?
Oh whoops. I couldn't read it due to the dark red on black until zoomed in further.Isn't .ch the Swiss TLD?
No wonder I can't see red. Lol
Thanks for your reply Victor.You're trying to update through China. Perhaps something is getting blocked going that route?
Sorry... You're not using the Chinese server - my mistake for not zooming in far enough.Thanks for your reply Victor.
I did not quite get it though, my ISP is from Argentina, and I don't use a VPN to ruote through China.
Please tell me I'm not hacked (once) again...
In TOP I'm seeing a proccess I don't recall (bwdpi), I've read its related to TrendMicro, what intrigues me is its location (/tmp/bwdpi)
Do you see anything strange?
Thanks once again for your help.
Thanks once again for your reply Victor.
Tried to change server but did not find that option.
Nevertheless, I tried pinging diversion.ch and its reachable
I do dirty upgrades all the time without problems. But sometimes, when I have a strange issue that defies expalantions, I have resorted to a hard reset and configure everything from scratch.Hi Jaime. Yes, I've been on 388.8_4 before but I had some issues (my bad, dirty upgrade), so I reverted back to 388.7.
Now I'm abroad, so no chance to updagre from scratch. Do you think it might be fw related? I've updated amtm a few times under this fw version.
No problem. Greetings from Chile!Regards and thanks for your help
Login via ssh and run this test:Do you think it might be fw related?
curl -v -o /dev/null https://diversion.ch/
# curl -v -o /dev/null https://diversion.ch/
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0* Trying 80.74.145.140:443...
* Connected to diversion.ch (80.74.145.140) port 443
* ALPN: curl offers http/1.1
} [5 bytes data]
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
} [512 bytes data]
* CAfile: /etc/ssl/certs/ca-certificates.crt
* CApath: none
{ [5 bytes data]
* TLSv1.3 (IN), TLS handshake, Server hello (2):
{ [122 bytes data]
* TLSv1.3 (IN), TLS handshake, Encrypted Extensions (8):
{ [25 bytes data]
* TLSv1.3 (IN), TLS handshake, Certificate (11):
{ [2609 bytes data]
* TLSv1.3 (IN), TLS handshake, CERT verify (15):
{ [264 bytes data]
* TLSv1.3 (IN), TLS handshake, Finished (20):
{ [52 bytes data]
* TLSv1.3 (OUT), TLS change cipher, Change cipher spec (1):
} [1 bytes data]
* TLSv1.3 (OUT), TLS handshake, Finished (20):
} [52 bytes data]
* SSL connection using TLSv1.3 / TLS_AES_256_GCM_SHA384
* ALPN: server accepted http/1.1
* Server certificate:
* subject: CN=diversion.ch
* start date: Feb 10 00:07:27 2025 GMT
* expire date: May 11 00:07:26 2025 GMT
* subjectAltName: host "diversion.ch" matched cert's "diversion.ch"
* issuer: C=US; O=Let's Encrypt; CN=R11
* SSL certificate verify ok.
* using HTTP/1.1
} [5 bytes data]
> GET / HTTP/1.1
> Host: diversion.ch
> User-Agent: curl/8.4.0
> Accept: */*
{ [5 bytes data]
* TLSv1.3 (IN), TLS handshake, Newsession Ticket (4):
{ [265 bytes data]
{ [265 bytes data]
* old SSL session ID is stale, removing
{ [5 bytes data]
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0< HTTP/1.1 200 OK
< Server: nginx
< Date: Fri, 07 Mar 2025 15:09:43 GMT
< Content-Type: text/html; charset=utf-8
< Transfer-Encoding: chunked
< Connection: keep-alive
< Vary: Accept-Encoding
< Cache-Control: no-store, no-cache, must-revalidate, post-check=0, pre-check=0
< Pragma: no-cache
< Expires: Fri, 06 Jun 1975 15:10:00 GMT
< Vary: User-Agent,Accept-Encoding
< Set-Cookie: PHPSESSID=2db7a7571b502e1d603fcda24ba510bf; path=/; HttpOnly
< Last-Modified: Fri, 07 Mar 2025 15:09:43 GMT
< Strict-Transport-Security: max-age=15768000; includeSubDomains
{ [15843 bytes data]
100 183k 0 183k 0 0 132k 0 --:--:-- 0:00:01 --:--:-- 169k
* Connection #0 to host diversion.ch left intact
Hi Dave.Login via ssh and run this test:
Post the full results.Code:curl -v -o /dev/null https://diversion.ch/
:/tmp/home/root# curl -v -o /dev/null https://diversion.ch/
} [5 bytes data]
} [512 bytes data]
* CApath: none
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0{ [5 bytes data]
{ [122 bytes data]
{ [25 bytes data]
{ [2609 bytes data]
{ [264 bytes data]
{ [52 bytes data]
} [1 bytes data]
} [52 bytes data]
* using HTTP/1.1
} [5 bytes data]
> GET / HTTP/1.1
> Host: diversion.ch
> Accept: */*
{ [5 bytes data]
{ [265 bytes data]
{ [265 bytes data]
{ [5 bytes data]
< HTTP/1.1 200 OK
< Server: nginx
< Date: Fri, 07 Mar 2025 16:43:51 GMT
< Pragma: no-cache
< Set-Cookie: PHPSESSID=de765b4a919b20095292770cf70e0675; path=/; HttpOnly
< Last-Modified: Fri, 07 Mar 2025 16:43:51 GMT
< Accept-Ranges: none
{ [15822 bytes data]
100 183k 0 183k 0 0 75499 0 --:--:-- 0:00:02 --:--:-- 92149
Looks normal, so what happens if you try to update amtm now?Here's the output:
curl -fNL --connect-timeout 10 --retry 3 --max-time 12 https://fwupdate.asuswrt-merlin.net/amtm_fw/amtm.mod | grep "^version="
find /jffs/addons/amtm/ -type f -exec ls -l {} +
Same error as always:Looks normal, so what happens if you try to update amtm now?
Try running this command and post the output:
Code:curl -fNL --connect-timeout 10 --retry 3 --max-time 12 https://fwupdate.asuswrt-merlin.net/amtm_fw/amtm.mod | grep "^version=" find /jffs/addons/amtm/ -type f -exec ls -l {} +
100 245 0 245 0 0 408 0 --:--:-- --:--:-- --:--:-- 560
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0ve rsion=5.2
100 38965 100 38965 0 0 17958 0 0:00:02 0:00:02 --:--:-- 63254
find: unrecognized: -type
BusyBox v1.25.1 (2024-04-26 14:22:44 EDT) multi-call binary.
Usage: find [-HL] [PATH]... [OPTIONS] [ACTIONS]
Search for files and perform actions on them.
First failed action stops processing of current file.
Defaults: PATH is current directory, action is '-print'
-L,-follow Follow symlinks
-H ...on command line only
Actions:
! ACT Invert ACT's success/failure
ACT1 [-a] ACT2 If ACT1 fails, stop, else do ACT2
ACT1 -o ACT2 If ACT1 succeeds, stop, else do ACT2
Note: -a has higher priority than -o
-name PATTERN Match file name (w/o directory name) to PATTERN
-iname PATTERN Case insensitive -name
-mtime DAYS mtime is greater than (+N), less than (-N),
or exactly N days in the past
If none of the following actions is specified, -print is assumed
-print Print file name
-print0 Print file name, NUL terminated
-exec CMD ARG ; Run CMD with all instances of {} replaced by
file name. Fails if CMD exits with nonzero
#!/bin/sh
#bof
version=5.0
release="November 17 2024"
amtmTitle="Asuswrt-Merlin Terminal Menu"
rd_version=1.3 # Router date keeper
fw_version=1.2 # Firmware update notification
wl_MD5=1cbf962ffa4593150bd1612352b1d131 # shared-amtm-whitelist
What’s curious is that it’s still running the 5.0 FW version, and not anything newer.Thanks for your help!
find /jffs/addons/amtm/ -exec ls -ld {} +
ls -l /opt/bin/curl /usr/sbin/curl
df /jffs
sh -x /usr/sbin/amtm 2>&1 | tee /tmp/debug.log
I’m too invested in this mystery to give up now!otherwise I´ll leave alone and live with it.
Hi Dave! Made some time today, here's the resultsI’m too invested in this mystery to give up now!Safe travels.
Might want to remove the amtm directory under addons and try again, but first run the commands above.
drwxrwxrwx 3 elbubi root 296 Dec 4 00:35 /jffs/addons/amtm/
drwxrwxrwx 2 elbubi root 232 Dec 4 00:35 /jffs/addons/amtm/a_fw
-rw-rw-rw- 1 elbubi root 41236 Dec 4 00:35 /jffs/addons/amtm/a_fw/ amtm.mod
-rw-rw-rw- 1 elbubi root 17 Apr 18 2024 /jffs/addons/amtm/.amtm_theme
-rwxrwxrwx 1 elbubi root 117672 Aug 14 2018 /opt/bin/curl
-rwxr-xr-x 1 elbubi root 124876 Apr 26 2024 /usr/sbin/curl
df /jffs
Filesystem 1K-blocks Used Available Use% Mounted on
ubi:jffs2 45528 3664 39504 8% /jffs
Did that, when executing amtm prompts me to select theme (as first install), then its still gives update error, but now in top left corner it says "amtm 5.2" instead of "amtm 5.0 FW" as before.Might want to remove the amtm directory under addons and try again, but first run the commands above.
Done the pastebin of this debug file, but I can't seem to reach you thoroug PM ("This member limits who may view their full profile", thus no PM option available)The next step would be to run the script like I show below. It will create a lot of output on the screen, and then prompt you for the menu choice. Enter u for update, let it scroll all the output, and when you get the menu prompt again, enter e for exit. Then PM me a pastebin link of the debug.log file. Your choice, if you want to go that far.
Try both commands:ls -l /opt/bin/curl /usr/sbin/curl -rwxrwxrwx 1 elbubi root 117672 Aug 14 2018 /opt/bin/curl -rwxr-xr-x 1 elbubi root 124876 Apr 26 2024 /usr/sbin/curl
/opt/bin/curl -fNL --connect-timeout 10 --retry 3 --max-time 12 https://fwupdate.asuswrt-merlin.net/amtm_fw/amtm.mod
/usr/sbin/curl -fNL --connect-timeout 10 --retry 3 --max-time 12 https://fwupdate.asuswrt-merlin.net/amtm_fw/amtm.mod | grep "^version="
mv /opt/bin/curl /opt/bin/curl.old
Try both commands:
curl: (77) error setting certificate verify locations:
CAfile: /home/tina/kao_asus/asuswrt/release/src/router/APP-IPK/DM-ipk/opt/share/curl/curl-ca-bundle.crt
CApath: none
version="
100 245 0 245 0 0 472 0 --:--:-- --:--:-- --:--:-- 511
0 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0version=5.2
100 38965 100 38965 0 0 18441 0 0:00:02 0:00:02 --:--:-- 34149
EDIT: In fact, that first binary is so old, you should justdeleterename it.
:/tmp/home/root# mv /opt/bin/curl /opt/bin/curl.old
:/tmp/home/root#
Welcome To SNBForums
