Diversion AMTM / Diversion stopped working (USB Drive?)
Dancing Lemur
I've been running AMTM/Diversion for years. Once I get it installed, I let it run and just make it sure it's updated. A little while ago, it stopped working. I saw a USB drive not recognized error and thought the USB drive wasn't working. But that seemed to be the case with a different USB drive.
I've tried reformatting the drive and that seemed to work. The router rebooted. But when it came back up and I tried using amtm to install entware (after diversion told me I needed that), I saw the error:
No compatible device(s) found to install Entware on.
A USB storage device formatted with one of
these file systems is required:
ext2, ext3, ext4
Use Format disk (fd) in amtm to format devices to ext*.
Is this a known issue that can be resolved? Or is my USB port broken? I have a RT-AX88U Pro running the latest Merlin firmware (3004.388.8_2). I didn't see any log messages that seemed relevant but I may not have been looking for the right things there.
If someone can point me in the right direction to help debug this, it'd be greatly appreciated. I don't touch this stuff actively until something breaks. Apologies if this was posted somewhere else.
Thanks,
Dancing Lemur
______________________
I saw something that said ext4 might not be working, so I tried with ext3 and managed to capture the message. I'm not sure why it's saying the drive is .1 GB. And it doesn't appear to detect /dev/sda1.
Dancing Lemur
Formatting sda SanDisk Corporation Anisha (0.1 GB) now!
_____________________________________________
Stopping file serving services and swap file
Unmounting device(s)
Zeroing disk sda SanDisk Corporation Anisha (0.1 GB)
16065+0 records in
16065+0 records out
Creating partition(s) on sda SanDisk Corporation Anisha (0.1 GB)
Device contains neither a valid DOS partition table, nor Sun, SGI, OSF or GPT disklabel
Building a new DOS disklabel. Changes will remain in memory only,
until you decide to write them. After that the previous content
won't be recoverable.
Command (m for help): Building a new DOS disklabel. Changes will remain in memory only,
Command (m for help): Command action
e extended
p primary partition (1-4)
Partition number (1-4): First cylinder (1-1016, default 1): Using default value 1
Last cylinder or +size or +sizeM or +sizeK (1-1016, default 1016): Using default value 1016
Command (m for help): The partition table has been altered.
Calling ioctl() to re-read partition table
Formatting disk as "ext3", enabling journalling
mke2fs 1.45.6 (20-Mar-2020)
The file /dev/sda1 does not exist and no size was specified.
Setting disk device label "AMTMDRIVE"
tune2fs: No such file or directory while trying to open /dev/sda1
Couldn't find valid filesystem superblock.
tune2fs 1.45.6 (20-Mar-2020)
I would recommend to use an external SSD instead of a thumb drive. SSDs are far more reliable and are built for the many read/write cycles while thumb drives are only for occasional use and wear out much faster.
I thought about that, though the price seemed 4-5x more -- if I had to replace the flash drive every year or two, that'd still be cheaper probably?
I might have an old SSD somewhere that I can try. But given I see similar things with different USB sticks, would you expect the port to work with that?
Cheaper, maybe, but a whole lot less reliable...
External SSDs are a more reliable and durable choice, especially for routers that require frequent writes or long-term operation. High-quality SSD chips can monitor usage, temperature, and health status, and their enclosures offer better heat dissipation compared to thumb drives (USB flash drives), helping to extend lifespan and maintain stable performance.
I accidentally discovered a rather unique thumb drive cooling solution, which surprised me with the creativity of the online community.
SSD vs. Flash discussion not withstanding, I think I may have more basic issues. I found a 1 TB SSD that didn't have anything I needed on it (I'll move to a smaller SSD if I find this works). I hooked up and tried to format it and saw this information below. It doesn't seem to recognize the size of the SSD. It didn't seem to format successfully. When I came came from the reboot, it still didn't detect the drive. Do I have a bad USB port? It recognizes a drive but doesn't seem to do much more...
Entware on.
ext2, ext3, ext4
devices to ext*
___________________
Here's the info on the formatting:
Formatting sda SanDisk Extreme Pro 55AF (0.0 GB) now!
Zeroing disk sda SanDisk Extreme Pro 55AF (0.0 GB)
dd: writing '/dev/sda': No space left on device
2+0 records in
1+0 records out
Creating partition(s) on sda SanDisk Extreme Pro 55AF (0.0 GB)
fdisk: can't read from /dev/sda
Formatting disk as "ext4", enabling journalling
Setting disk device label "AMTM"
I'm not sure if your SanDisk Extreme Pro is experiencing a similar issue to the one reported last year. If it is still under warranty, I recommend contacting the manufacturer for a replacement or repair to ensure your rights are protected.
Are you formatting the drive on a PC first to NTFS, then taking it to the router, plug it in , then reboot the router?
When it comes up as seen by the router, (Mounted) then go to AMTM and format as EXT4 with Journaling enabled.
I would also update this to the new test build for security:
I use a variety of USB devices on my routers.
The less used test routers still use USB sticks, one of it is currently 24 years old, an IOMEGA 250 MB model. They work fine for their occasional use
On the Main router RT-AX88U a Samsung Portable SSD is doing its job fine 24/7.
The primary test router RT-AX86S with a conventional Corsair SSD works fast and really great.
The still-not-having-a-final-Firmware-release test router GT-BE98 has a SanDisk attached.
If I want to speed USB things up on any router for testing, I simply attach an NVM SSD to the USB3 port. The difference can be amazing, especially on older routers!
So with travel and the holidays, I put this on the back burner. I had tried a bunch of USB drives and a Samsung SSD at the time and the router couldn't format them -- when I tried, it exited immediately. I thought that the USB port was broken. So I suffered ads (Diversion is important to me!) for a couple of months.
Now, two months on, I was going to call ASUS even though my RT-AX88U Pro is out of warranty. But before I did that, I upgraded to the latest Merlin firmware (3004.388.8_4). Then I tried to format a USB drive. To my surprise, it worked. I installed Entware and Diversion and they seem to work. Skynet and uiDivStats shows as installed but had to be uninstalled and reinstalled for them to work. I have no idea what happened here. Maybe something in the new build? Maybe it's still an intermittent USB port issue?
So all that being said, I'm thinking of migrating to a SSD drive. What are some current recommendations? Is it better to get a bare SSD drive and enclosure than one of the WD/Samsung ones? I imagine I don't really need a big one. It'd be nice not to spend too much money but enough to get something more reliable than a USB flash drive.
Thanks!
Thanks!
Similar questions have been asked and some recommendations have been made. Please see link below:
Thanks! I wasn't sure if the drives in those links would still be the best or still available. But I did find the 120GB Parrot Elite SSD mentioned in one of the links still available. I just ordered that and an enclosure. It was much cheaper than the available WD/SS all-in-one SSDs so I didn't think too much about it.
Installing on the SSD was a breeze. It had a USB3.0 connection and was super fast -- makes me think that the USB Flash drives I had been using probably wasn't 3.0. 120GB still feels like overkill but it was cheap. I feel like I should be installing more on it now!
Anyway, thanks for all the help/advice.
