L&LD
Part of the Furniture
You're welcome.
If USB 3.0 mode works well for you, your devices, and your 2.4GHz Wi-Fi use, there is no reason to not use it. But, depending on the USB drive, the router, and the network usage, it may interfere with the 2.4GHz band.
Right now, there is no way to use a bigger than 2GB swap file, officially. Officially meaning amtm sanctioned!
Thankfully, we don't seem to need it (yet).
RAM usage is normal. The numbers you're seeing are from the 4TB drive you have attached. A proper NAS is recommended instead.
I'll let others chime in, for your other question.
