L&LD
Part of the Furniture
@Ronald Schwerer are you also running the disk checker (at boot)?
Bit confused. I just updated seconds ago, but I still get the 'u' loop
(384.15 firmware version of amtm)
amtm minor update
OK, second bug fixed. Though I have not yet figured out why exactly that caused a loop when the disk-check is enabled with dc.
Use uu to update amtm to this latest bug fix version.
amtm minor update
@Martineau thanks all good here now, RT-AC86U and 384.15_0 with disk-check script installed.
Yeah, @Martineau had no hand in that@Martineau thanks all good here now, RT-AC86U and 384.15_0 with disk-check script installed.
Fixed my issue. Thanks!OK, second bug fixed.
You should be thanking @thelonelycoder instead.![]()
Both work, but:R reset fixed it for me.
I thought so, but I've only tried it (rebooting) once since I installed it.@Ronald Schwerer are you also running the disk checker (at boot)?
Apparently it isn't installed since it doesn't show up with the active scripts. But running 'r' sounds like it removed dc, and I didn't re-install it after the r.
Both work, but:
uu leaves non-third party scripts installed, like the disk-check or reboot scheduler while r removes them.
Welcome To SNBForums
