sfx2000
Part of the Furniture
Does an antenna's nearness to a wall create a 'splash-back' effect for WiFi signals? (Let's assume it's a transmit-thru capable wall, too.)
I think I need to find out if a signal, once it leaves the antenna, is broken into some packet-sequence that requires "flight distance to form up", like a 300-plane bomber raid takes an hour for all to take-off, so they circle and wait for everyone and then 'form up'.
This assumes, then, that a WiFi signal can self-validate in-flight (NO, IT CANNOT) and thus it could send back re-transmit requests to the WiFi origin point. I prefer to believe packet-validation is only performed upon Destination Receipt, or perhaps in Transmit Checks (the router knows "I coughed - I'll just retransmit that signal now, automatically").
The nearness to a wall might create a validation-error at the Antenna itself if the "flight of WiFi bomber signals" required a flight-formation transit.
I just don't think that's true, though.
Therefore - does an antenna's distance from a wall matter? Is six inches better than 1 inch? Is 18 inches better than 6?
1/4 wavelength in free space is 30.7mm with a dipole antenna...
In Imperial measurements, that's about an inch and a quarter and some spare change...
Most households are sheetrock, with has about 3dB attenuation... Plaster/Lath (chicken wire) is about 5 dB - no "splatter"/self-jamming by the AP. None of these reflect anything back to the antenna of the transmitter... just a harder path to punch thru for the Tx/Rx path.
Best guidance here for 2.4GHz and 5Ghz - don't put the AP on top of a metal base (e.g. file cabinet), as this can impact the beam patterns.
Plastic/Wood base - this is ok...
sfx
