Thanks for taking the time to reply .I'm using that on mine, I haven't had anything worrisome to report on as of yet.
Thanks Tech but I no longer have the patience to play around , just want a solid connection , Guess I'll wait for Merlin to release this FW at least then I know the FW will work with no surprises getting old sucksSave your current configuration Jerry, test the new firmware and see if you like it. If not - flash back what you like better and restore the configuration.
I am installing it now.Thanks Tech but I no longer have the patience to play around , just want a solid connection , Guess I'll wait for Merlin to release this FW at least then I know the FW will work with no surprises getting old sucks
Good luck , let us know how it works ,.I am installing it now.
I almost hit the button! Then I remembered that I don't have the Pro variation lmao. Sorry y'all.Good luck , let us know how it works ,.
Thanks , the XT9 is probably the problem as it is not on 3.0.0.0.6 I'm not sold on wifi7 yet 6e is good enough for now if I'm in range 20 to 30 feet from the router I'm getting close to full 1gig transfers wirelessfrom the internet close to 2 gig wireless intranet . I'll wait to see the range wifi7 has before I buy a new routerI tested this last week since I switched to OPNsense and was only using the GT-AX11000 Pro as an AP and it didn't go well. I'm betting it was due to having an XT9 as a node and that still being on 3004. Half my devices didn't have internet even though they showed connected in the UI, so I switched back and will leave it on 3004 till I switch the XT9 or switch completely to WiFi 7
Welcome To SNBForums
