I'm new here and also new to the Asuswrt-Merlin and the ASUS AC87 router. I've been trying to get VPN running but have not been able to get my iphone to connect successfully. Are there any known issue that I need to watch for?
Followed basic FAQ found on ASUS website to set it up but getting the following error logged:
Aug 6 00:04:51 pptpd[5874]: CTRL: Client 166.205.XXX.XXX control connection started
Aug 6 00:04:52 pptpd[5874]: CTRL: Starting call (launching pppd, opening GRE)
Aug 6 00:04:52 pptp[5875]: Plugin pptp.so loaded.
Aug 6 00:04:52 pptp[5875]: PPTP plugin version 0.8.5 compiled for pppd-2.4.5, linux-2.6.36.4
Aug 6 00:04:52 pptp[5875]: pppd 2.4.5 started by admin, uid 0
Aug 6 00:04:52 pptp[5875]: Using interface ppp10
Aug 6 00:04:52 pptp[5875]: Connect: ppp10 <--> pptp (166.205.XXX.XXX)
Aug 6 00:04:52 pptp[5875]: peer refused to authenticate: terminating link
Aug 6 00:04:52 pptpd[5874]: CTRL: EOF or bad error reading ctrl packet length.
Aug 6 00:04:52 pptpd[5874]: CTRL: couldn't read packet header (exit)
Aug 6 00:04:52 pptpd[5874]: CTRL: CTRL read failed
Aug 6 00:04:52 pptpd[5874]: CTRL: Client pppd TERM sending
Aug 6 00:04:52 pptpd[5874]: CTRL: Client pppd finish wait
Aug 6 00:04:52 pptp[5875]: Terminating on signal 15
Things of interest on the router:
VPN STATUS on the router shows 2 VPN Server running
- PPTP VPN Server - Running
- OpenVPN Server 1 - Running
Not sure where the OpenVNP Server came from but I believe it was there when I upgraded to this version of the firmware.
Router has the following setup:
VPN in enabled
Server mode is PPTP
Network Place (Samba) Support is set to No
UserName/Password has been set
Broadcast Support is set to Two-way
Authentication is set to Auto
MPPE Encryption is set to 128
Client IP has been set and does not have overlap with IPs set for DHCP
DDNS has been set
The iphone's VPN setup is:
PPTP
Server points to DDNS (I've also tried using IP but get the same error)
RSA SecurID is disabled
Account and Password match VPN server's
Encryption Level is set to Auto
Send All Traffic is enabled
Anyone had better luck? Any idea why AC87 shows two VPN instances running?
Appreciate any help anyone can offer.
Thanks.
Michel
VPN in enabled
Server mode is PPTP
DDNS has been set
PPTP
Thanks.
Michel
