Hi, great site and often my first port of call for great advice. Snb was first intro to ubuntu and nas servers (still running well 2 years later, thank you!)
I need some advice on networking a large country estate with several separate buildings with thick stone walls.
Each of the buildings have got cat 5 but the number of outlets are very limited. The broad plan is to use a single router for dhcp for the site. I wish to then use a combination of several ethernet switches and wireless access points to cover the site. Unfortunately some of the rooms will need some sort of wireless bridging or similar technology as I can't get the cat 5 everywhere as the building is too large.
It seems to me that I should purchase a bunch of identical wireless n routers and switch off dhcp. This gives me maximum flexibility to hang pcs and printers off a location and also provide an access point which could also be a bridge or similar.
Absolute speed is not a priority albeit who likes a slow network. Extensive features seems important due to the different duties each of the boxes might perform. Stability is a must. Reasonable qos for voip is helpful.
In terms of price, a 'bmw' seems right as opposed to a porshe or a Hyundai.
Any suggestions would be most appreciated.
Regards
Mark
Ps. I have assumed that simple access points are exactly that and for a very small extra cost, the wireless routers deliver vastly more features?
Regards
Mark
