Are the Entware installation instructions stale?
SnakeByte
I'm attempting to install Entware on an ASUS RT-AC68U with firmware 3.0.0.4.374.38_1.
I'm following the instructions here.
The "easy" way states that I just need to run the existing entware-setup.sh shell script, yet it doesn't exist anywhere in the filesystem.
Following the "old" way has me download the script and run it, but that fails:
wget -O - http://wl500g-repo.googlecode.com/svn/ipkg/entware_install.sh | sh
Connecting to wl500g-repo.googlecode.com (74.125.25.82:80)
- 100% |*************************************************************************************************************| 1101 0:00:00 ETA
Info: Checking for prerequisites and creating folders...
Info: Opkg package manager deployment...
opkg 100% |*************************************************************************************************************| 456k 0:00:00 ETA
Connecting to wl500g-repo.googlecode.com (74.125.20.82:80)
opkg.conf 100% |*************************************************************************************************************| 112 0:00:00 ETA
Info: Basic packages installation...
/opt/bin/opkg: line 1: syntax error: unexpected "("
Info: Cleanup...
Info: Congratulations!
Info: If there are no errors above then Entware successfully initialized.
Info: Found a Bug? Please report at wl500g-repo.googlecode.com
Is my particular router incompatible with this, or are the instructions no longer valid?
Entware doesn't work on the RT-AC68U. Entware is only for MIPS-based routers, and the AC68U is ARM-based.
As of now you have to use Optware - see instructions here. :rolleyes:
With kind regards
Joe :cool:
Thanks Joe. I think you meant this link.
And just in case someone else reads this, that link isn't even necessary. Simply install Download Master from the USB Application menu to install optware. (You can then uninstall Download Master afterwards since, apparently, optware stays put.)
I think that's the best option with DD-WRT FW.
I tried a DD-WRT FW for a while and DNLA (which is a broken in official releases and merlins releases after 36) is a thing of beauty, super fast.
What exactly is broken in Merlin build?
Sent from my HTC One using Tapatalk
From 37 and up miniDLNA doesn't play properly some media (video) files. Many users reported this, including me. e.g.
- you can't play the whole movie, it stops after a while (10/15 minutes)
- rewinding is almost impossible, it hangs after a few tries
I made a debian build for arm devices with minidlna included, maybe later I will post the link because I'm not at home right now.
It's similar with this http://forums.smallnetbuilder.com/showthread.php?t=14573
yeah man, tnx, I saw your post before but it wasn't for arm devices;
I'll definitely try it, cheers
edit:
not worth reading ...
just like merlin wrote in a second post Entware doesn't work with AC68U
