5 - prepare Debian's init.d script
By default, all subdirs of/tmp/mnt/
(except the Entware partition) will be bind-mounted on chrooted Debian's/mnt/
(making them visible by Plex Media Server).
apt install whiptail
apt install locales-all
/usr/sbin/init
check (step 10)I’m still using Plex on my RT-AX86S, and everything works perfectly.Anyone out there still using this as a solution? I am going to attempt this in the coming week. It seems entware servers are down at the moment, though
Hey there. Thanks for your tutorial. I am blown away at how well it works and how much I love plex.Tutorial updated with:
- update procedure
/usr/sbin/init
check (step 10)
The installation process has likely not changed, so the guide should still be up-to-date.
Welcome To SNBForums
