Aria2 install manual
I installed and started this manager.But not working download.Web interface when loged is empty.What is bad?I installed only aria2 with putty.Change password and download directory to mnt/sda1/Downloads
Did you open the right ports?
http://aria2.sourceforge.net/manual/en/html/aria2c.html#files
According to the sample configs you would need to add this to the /jffs/scripts/firewall-start script:
iptables -I INPUT -p tcp --destination-port 60000 -j ACCEPT
iptables -I INPUT -p udp --destination-port 60000 -j ACCEPT
Change 60000 to what ever port you specified in the Aria2 config file.
Using Aria2 download manager
Prerequisites
asuswrt-merlin firmware on board and a USB drive with an Entware installation.
1. Installation
Install aria2 package:
opkg install aria2
2.Configuration
Edit /opt/etc/aria.conf file, at least, two lines must be changed:
dir=/opt/var/aria2/torrents
rpc-secret=Passw0rd
The first one is a folder where torrent content will be placed, the second one is a web-interface password.
Now, create /jffs/scripts/firewall-start file with the following content:
#!/bin/sh
iptables -I INPUT -p tcp -m tcp --dport 6800:6801 -j ACCEPT
iptables -I INPUT -p udp -m udp --dport 6801 -j ACCEPT
and make it executable:
chmod +x /jffs/scripts/firewall-start
That's all, reboot router and pick one of web interfaces.
3. Using web interface.
You don't need to place WebUI files into router, pick webui-aria2 or yaaw. I prefer the last one. Configure WebUI with following string:
http://token:[COLOR="Red"]Passw0rd[/COLOR]@[COLOR="Red"]111.222.111.222[/COLOR]:6800/jsonrpc
where "Passw0rd" is a keyword from /opt/etc/aria.conf file and "111.222.111.222" is an IP address of the router.
Pro:
  • Supports HTTP(S), FTP, BitTorrent, and Metalink.
  • Small and fast, easy to use.
  • Do not requires a web server for WebUI.
Contra:
  • uTP is not supported.
  • no day/night scheduler.
Securing connection between aria2 and browser
This is an option part.
While using WebUI, our browser is "talking" with Aria2 via HTTP protocol. There is a way to secure this connection by using HTTPS.
1. Create certificate
openssl utility comes form asuswrt-merlin firmware. Please, leave "Password" field empty when it's prompted:
cd /opt/var/aria2
openssl req -x509 -nodes -days 3650 -newkey rsa:1024 -keyout aria2.pem -out aria2.pem
openssl pkcs12 -export -out aria2.pfx -in aria2.pem -name "Aria2 Certificate"
2. Edit Aria2 configuration file
Uncomment following lines in /opt/etc/aria2.conf:
rpc-certificate=/opt/var/aria2/aria2.pfx
rpc-secure=true
3. Edit WebUI settings
Reboot router or restart Aria2 manually:
/opt/etc/init.d/S81aria2 restart
If you are using yaaw, edit connection string by adding "s" after "http":
http[COLOR="Red"]s[/COLOR]://token:Passw0rd@111.222.111.222:6800/jsonrpc
PS Firefox denies to use self-signed certificate, you have to add it to the trusted list. Point browser to
https://111.222.111.222:6800/jsonrpc
and click "add this site to trusted, permanently".
