Voxel Custom firmware build for R7800 v. 1.0.2.114SF
Voxel
Part of the Furniture
Continuation of
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-112sf.93224/
https://www.snbforums.com/threads/custom-firmware-build-for-r7800-v-1-0-2-113sf.93764/
New version of my custom firmware build: 1.0.2.114SF.
Changes (vs 1.0.2.113SF):
1. Toolchain: Go is upgraded 1.23.5->1.24.2.
2. OpenVPN is upgraded 2.6.13->2.6.14 (fixing CVE-2025-2704).
3. OpenSSL v. 3.0.x package is upgraded 3.0.15->3.0.16 (fixing CVE-2024-13176, CVE-2024-9143).
4. expat package is upgraded 2.6.4->2.7.1 (fixing CVE-2024-8176).
5. DNSCrypt Proxy v.2 is upgraded 2.1.7->2.1.8.
6. dropbear package is upgraded 2024.86->2025.87.
7. util-linux package is upgraded 2.40.4->2.41.
8. curl package is upgraded 8.11.1->8.12.0.
9. proftpd package is upgraded 1.3.8c->1.3.9.
10. fcgi package is upgraded 2.4.2->2.4.4.
11. nano package is upgraded 8.3->8.4.
12. coreutils package (sort/gnu-date) is upgraded 9.5->9.6.
13. patch package is upgraded 2.7.6->2.8.
14. jansson package is upgraded 2.14->2.14.1.
15. gdbm package is upgraded 1.24->1.25.
16. libusb package is upgraded 1.0.27->1.0.28.
17. libflac package is upgraded 1.4.3->1.5.0.
18. Remove 'netatalk' and 'netatalk-utility' to avoid oversize.
19. Remove 'libgcrypt' and 'libgpg-error' used by 'netatalk' to avoid oversize.
20. kmod-kcode: compress binaries by UPX to avoid oversize.
21. Several packages: '-Os' optimization to avoid oversize.
22. transmission: 'Makefile' typo correction.
23. Host tools: upgrade xz to 5.8.1 (fixing CVE-2025-31115).
The link is:
https://www.voxel-firmware.com (thanks to vladlenas for his help with hosting).
NOTE:
This version removes all packages related to 'netatalk'. Reason for removal: firmware image oversize due to multiple package updates.
If needed, I can build netatalk and related packages and post them for you to download and manually install. If you need, please post your request here.
What is Netatalk:
https://netatalk.io/docs/
Voxel.
Hi, thanks Voxel for keeping the router running.
This question has probably already been answered, but my router keeps disconnecting due to DHCP. What would be the solution?
