dosborne
While I understand that it hasn't been an issue for you so far, I strongly recommend that you consider doing as I have done, and set manual static IP addresses *and* DHCP reservations for critical infrastructure equipment., I don't have even a single one using a manually set static IP.
Scenario: your router fails. All your reservations are lost and something as simple as printing or accessing a file becomes instantly a pain in the butt.
Scenario: you have to reset your NAS (or insert device here) and it defaults to DHCP so is not assigned its usual IP (I know this is what you are already covering in your setup - this is mentioned more for others who don't do both).
The effort required to do both is miniscule and can be done one device at a time, when convenient, but *potentially* save a buttload of aggregation should something happen and leaves you scrambling to figure things out with the wife and kids screaming their internet is down
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Obviously everyone makes their own decisions about what works best, but having been there trying to figure out what happened at 4am.....
