Asus ac3200 and ac68u
siri_uk
Hi guys,
I have been using a rt-ac68 router, I have managed to get hold of a ac3200. I want to connect the 2 together and use the ac68 as a vpn with my windscribe account for the streaming boxes and iptv and the ac3200 as my main router for everything else (phones, pc etc). What would be the easiest way to link them..lan to lan, lan to wan or wireless?
Hi.
Do you really need two routers/ac-points to get enough Wifi signals? The AC3200 will be better for VPN because of CPU.
But here goes my suggestion: Internet -> AC3200 WAN and AC3200 LAN -> AC68 WAN.
Always use cables if possible, because of speed and security.
Regards
Hi.
Regards
I'd agree with Stardust for the most part. The only real point of connecting the two would be to extend your wireless coverage and availability. If that's the case, use the ac3200 as your primary router and VPN. Use the AC68 in AP mode effectively making it transparent. You can advertise a different SSID than the AC3200 and have wireless and available wired ports that will not be subject to double NAT.
Sent from my MI 5 using Tapatalk
Hi.
I agree with you roguetr, I just not made it clear enough. I was mainly writing about the connection...
Your answer was spot on with answering exactly what was asked. I just gave my opinion and said what you alluded to :D
Sent from my SM-T815Y using Tapatalk
phillyaj Xfinity Gigabit x2 Plan and ASUS RT-AX86U Other LAN and WAN 6
