I need new router to replace my good old WRT54GL with DD-WRT
So, after browsing and searching, I decided to go with either AC68U or R7000.
These are my requirements:
- stable
- stable
- stable
- VPN server support
- VLAN Tagging support
- WAN-LAN and LAN-WAN 200mbit throughput with VPN
- QoS is optional
It is no problem to put some other firmware on router, I just want it to plug it in and forget about it after I configure it, otherwise it might end up in the wall...
So, I need recomendation.
Thanks!
- stable
- stable
- stable
- QoS is optional
Thanks!
