mightyberry
Hello,
So I own a Asus AC68u router with Merlin 380.59 firmware and a Western Digital My Passport Ultra attached to it via USB 3.0. The USB 3.0 noise reduction is set off.
Normally I get transfer rates while copying files from the drive to my PC of around 40-50 megabytes per second (large files). Than when I need to reboot the router either from the webui or command line the transfer gets stuck at around 27 megabytes per second are won't go any higher, even for a second. Basically the transfer rates are similar to what I get wen the drive is connected to a USB 2.0 port
Sometimes when I reboot the router by removing the power cable or using the power button the transfers go up again... until the next reboot. I simply don't get it.
Has anyone came across a similar issue?
And yes I understand that router is not a NAS and I can't expect that level of performance.
Right now after doing a factory reset to official asus firmware and than flashing the latest Merlin (setting up everything from scratch) I get transfers around 48MB/S with Transmission and DLNA running in the background. This is perfectly fine for my needs.
But I'm certain that once I reboot the router from the UI, the transfer will again be stuck at 27 MB/S. So basically I would like to know how to keep this level of performance.
Regards,
Regards,
