(Asus AC86u / Merlin 384.16) OpenVPN client not saving cert file
Bummer. For other things to try, you might check out some of the instructions in L&LD's profile. Most problems can usually be resolved by meticulously going through the steps in those various documents for resetting. Hopefully one of them will get you fixed up.
Ok. I came across a few of L&LD's posts when researching this. I'll try some out this weekend. If I find a fix, I'll send a follow-up post. Thanks for your help!
