ASUS AC87u 5Ghz, Samsung Devices Batterydrain?
MacIT
I just bought a Asus AC87u router, but when i connect my Samsung Galaxy S4 and Tab S 2 with the 5 Ghz WiFi. The battery of my devices are draining. My iphone works wel with 5Ghz.
Is there a way to fix this?
SUS RT-AC87U Firmware version 3.0.0.4.378.9383
- Release Notes –
- Added Movistar Triple VLAN profile in IPTV setting page
- Fixed too many repeat information in system log.
- Fixed Traffic analyzer issue UI issue when changing the data.
- Added workaround for Android devices power drain issue.
- Fixed Adaptive QoS bandwidth setting issue.
- Fixed low samba transfer throughput issue when enable bandwidth limiter.
- Fixed web history related issue.
- Fixed abnormal bandwidth increasing in bandwidth monitor.
- Fixed VPN client UI issue when using Firefox.
- Fixed wireless channel issue when set 2.4G channel in 12 or 13 (only for EU region)
- Fixed dual wan ping time watch dog issue which might cause .false fail over to secondary wan.
- Fixed Bandwidth monitor and Web history UI issue which was caused by "<" or ">" in SSID.
- Fixed vulnerability of the cross site scripting
i see that asus added a workaround in there firmware? isnt this applied on the Merlin versions?
Asus haven't released the GPL for later than 378.9313 for many routers, so quite likely this Quantenna specific patch not in merlin releases.
