Asus AiMesh in Ap mode and 2 nodes
yes I had that firmware , updated it a few days ago , to Firmware version 3.0.0.4.384_81039 on both 68u and 1900 same result,
I'm out of ideas. The 1900 is suspect. Could try the router mode test. Could return it for an 86U. Could swap it with the 68U... make the 1900 wireless and 68U wired.
OE
OE
Same here , that's why I thought I would give you guys a try , And I appreciate the all the reply's , thanks .
I would reset ALL 3 routers to factory with initialize
load previous (stable) firmware on them TWICE
factory reset all again
only power on one at a time for all those steps!
and start over with 5300 minimal setup
then mesh with one and then the other node.
