Asus AX86U poor WAN speeds
As expected with the WAN port connected to the Virgin Hub I get 940mb/s download speed with a wired PC. If I change the WAN configuration to use the 2.5GB port, I still get 940mb/s on a speed test to the wired PC, due to the speed limit on the 1GB LAN ports.
Your router must be defective too...
You can actually see >Gigabit aggregate traffic when using 2.5GbE port for WAN and Wi-Fi + LAN at the same time. Also if you push 160MHz wide channel to 160MHz capable client. Common 2-stream client will have 2400Mbps link speed with up to 1.7Gbps throughput. Close to the router, of course.
