I currently have a network of 8 x AX92u's. There's definitely been some ups and downs with prior firmware but my units are now running extremely well.
I am building a new site which will initially only need 2 nodes, it will be connected to 1Gb/s symmetrical fibre. I am thinking this would be an ideal time to go for the XT8's. Unfortunately with Asus, newer doesn't always mean better so I would like to weigh up the pros and cons.
AX92u has dual core 1.8ghz, XT8 has quad core 1.5ghz. Which CPU has the best single core performance?
Does the XT8 have the same (or better) range than the AX92u?
Has anybody here upgraded from AX92u to the XT8?
One of the "hidden" features of the AX92u was the ability to operate with a wireless backhaul but also have triband mode with the clients sharing access with the 5ghz2 160mhz backhaul channel. This means clients get the full 1gbps. Can the XT8 also do this?
