Asus BE96U Initial setup
waldo142
I have upgraded to the Asus RT BE96U from the RT AC5300 I use just under 70 Manually assigned IP Addresses. I entered these as well as about 25 Port forwarded devices. I have noticed that I am now at 62% Memory at 1263 MB That is about twice of my old 5300 with the Mac Filter List completed.. about 25 entries. My Question
1. Have I done something wrong to create high memory useage?
2. I can not locate the Mac Filtering list under Wi Fi....There is no Header for it!
3. I have used the Merlin Firmware on my 5300 for Years.... am I correct that there is not one available at this point for the RT BE96U?
4. I have on this router 2 lan10G ports... can I use them to connect to my 2 main switches which are only Gig switches.?
My devices consist mostly IP Cameras..Sonos & Google speakers and the usual tablets & phones. at most 2 users sometimes. Cat 5e & 6a wiring.
Firmware 3006.102.37038
Any help is appreciated.
The Asus-Merlin supported routers are listed on the Asus Merlin website:
RT-BE96U3006.102.2_2
No, your new router has different hardware, run on different firmware and needs more RAM. The reason it comes with 2GB RAM.
