Tech9
Part of the Furniture
Must.... get.... every..... megabit.....
You were right... half of the troubleshooting around is about chasing speedtest numbers.
Define "properly handle"?Guys, that's not the issue. The question is. Can this router properly handle a 1g connection. But that seems to be doubtful.
But buying a new one would also be doubtful since only the wifi chip changed. Or i need to buy something like the ax6000 since it has more horsepower.
But i really don't need to whole ax stuff yet.
Nah.. this is always the response when someone is having doubts about the performance of a consumer product. Buy enterprise gear..... Thrust me that ain't all pink clouds and rainbows.If you are that concerned about getting most out of your 1 Gig connection, you may need to move to more robust business class hardware instead of home consumer stuff.
That may be true, but neither is using old hardware that was never designed to handle 1 gig speeds.Nah.. this is always the response when someone is having doubts about the performance of a consumer product. Buy enterprise gear..... Thrust me that ain't all pink clouds and rainbows.
Even then I am still good with my measly 300Mbps service?GT-AC2900 is 2.9Gbps router. Your XT8s are 6.6Gbps routers. You want more? GT-AXE16000 is 16Gbps router.
What's not in the User Manual: (click to reveal the secret)
As long as you don't hit firmware option disturbing NAT hacks in place. Then all of the above - 0.4Gbps routers.
So i cannot combine ax and ac aimesh?The same vertical style router - RT-AX86U Pro. This is the newest hardware available. It still relies heavily on NAT acceleration techniques. Otherwise about 400Mbps WAN-LAN traffic capable through the CPU. Home routers are built for power efficiency as well. You can't compare with x86 PC hardware. Your old PC is perhaps faster than any home router on the market - current and in next few years. Based on feedback - your AC68U may not work well in AiMesh.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
