AndrewJacob
Hi everyone,
I just recently bought an Asus GT-AX11000 and have set it up the basic way. I have a 2 story home that is blanketed by it's 5Ghz indoors and is able to maintain my 450Mbit speeds throughout the home. On the ground floor, near the patio door, I have a second router which is an AC router from my ISP and it's a Zyxel EMG2926. I use that one for getting a strong signal to the patio when I am outside with guests and it's on a different SSID. I have been using my iPhone 11 Pro as a tester (it's a solid Wifi 6 client albeit 2x2), and have noticed that the ping I am getting from the Asus router isn't great (10 to 14 ms depending on the site I am using for testing). I originally wanted to be hitting pings closer to the 4-5 ms range after having looked at reviews of the AX-86U which seems to excel in that area. Hopefully getting similar results with an AX11000 is realistic...
What can I do to improve my ping? Would appreciate any help.
Thanks,
Andrew
Thanks,
Andrew
