asus GT-AX11000 temp?
is it oriented to blow air down into the router or pull air up out of the router?
It will work both ways. I would prefer to reverse the natural convection air flow with fan on top blowing in and place a dust filter on fan's intake side. This way both the fan and the router internal components will stay cleaner and the maintenance will be easier.
AXE11000 AI mesh doesn't work with latest router firmware. It can not see the reset router with default name.
router.asus.com/ajax_coretmp.asp
router.asus.com:8443/ajax_coretmp.asp
depending on HTTP or HTTPS access (with the default port)
