Spartan
Download = https://rog.asus.com/networking/rog-rapture-gt-ax6000-model/helpdesk_download/
Do not forget to right-click on the file you just downloaded, go to Properties, then check the unblock button at the bottom if it says it was blocked because it came from the internet. If you don't do this, it might lead to erroneous installation as the file wouldn't have the proper privileges.
Please unzip the firmware file first then check the MD5 code.
MD5: 38bc8628f5bf44f001dc0f554036620f
Direct Download link: https://dlcdnets.asus.com/pub/ASUS/wireless/GT-AX6000/FW_GT_AX6000_300438822068.zipVersion 3.0.0.4.388.22068
54.82 MB
1. Improved system stability.
2. Fixed the IPsec VPN compatibility issue with Win10.
3. Fixed the VPN fusion user interface issues under the HTTPS connection.
4. Fixed Client DOM Stored XSS vulnerability.
5. Improved Wireguard performance.
6. Fixed the WAN setting GUI bugs.
