Release ASUS GT-AX6000 Firmware version 3.0.0.6.102_34797 (2024/10/01)
Great that you managed to solve the problem. In my Windows 10 both of these parameters are set by default. The 24H2 update probably changes it.
Updating fails. Someone suggested doing a factory reset.
How does that impact AI Mesh setup? My GTAx6000 is the main router, with two other routers as nodes attached via wires. Will the node routers get reset too? Will I have to reconfigure them? Or will they stay in mesh mode?
if you not do factory defaults then yours nodes will still here.
Just a heads up, I had issues with my LAN side 2.5 Gbps port not delivering, it did in fact not even reach full Gigabit speeds, which a hardware reset fixed. So there seems to be some kind of bug when doing a dirty firmware update.
Thank you, I understand that. But upgrade without factory reset is failing. So I was asking about what if I factory reset my main router so I can install the update? will the nodes need to be reconfigured, or will they stay in "node mode"?
When you reset the router firmware, you are restoring it to its unconfigured default state with default settings that belong to that firmware. This will obviously clear any AiMesh configuration in the router, so it will no longer connect to any existing nodes. You must then rebuild your network.
I suggest you remove all nodes from the AiMesh to automaticaly reset them before you tear down your router/network. Then reset and configure your router firmware from scratch, including adding your nodes to create your AiMesh.
FW Reset FAQ
Reset button/webUI Restore/node removal clears settings in NVRAM; reboot restores fw defaults from CFE
Hard Reset via WPS button/webUI Restore+Initialize also clears data logged in /jffs partition
OE
before factory default you should remove nodes from router gui, then nodes also do factory default, and be visible for router after upgrade.
Hi. Unfortunately, this program was causing me problems. I updated it before the weekend when we went to my parents'. When I got back, the router was flashing and I couldn't connect to the network. I turned it off and on again. Finally, I restored the factory settings. The next day, after I got home from work, the internet was disconnecting every 20-30 minutes. I re-uploaded the program. Unfortunately, nothing helped. I went back to the previous program. [Editor note. Translated from Polish. OP has been messaged.]
dziwna sprawa. U mnie działa bez problemu od momentu wgrania.
New firmware version out for the Asus GT-AX6000
ASUS GT-AX6000 Firmware version 3.0.0.6.102_34810
Bug Fixes and Enhancements:
1. Strengthened input validation and data processing workflows to further protect information security.
2. Enhanced AiCloud password protection mechanisms, safeguarding against unauthorized access attempts.
3. Enhanced device security through improved buffer handling in connection features.
4. Refined data handling processes, ensuring secure and accurate information management.
5. Enhanced file access control mechanisms, promoting a more secure operating environment.
6. Strengthened certificate protection, providing Enhanced data security.
Cześć. Gdzie dostępne
Hello. Where available
