Release ASUS GT-AX6000 Firmware version 3.0.0.4.388.23285 (2023/05/12)
Unfortunately, yes.
I don't mind that the UI is generally atrocious, but is there an easy way to get rid of diablo 3 / overwatch tracking from main menu on stock fw?
lol
I've never heard of that type of tracking on a router before. Show some screenshots and provide further information of how you've setup the router and how you're using it.
It’s a pane on main menu when going to asusrouter.com
That's not tracking. That is called 'stats'. :)
The RMerlin firmware doesn't show such garish information when connected via a browser via a PC (I don't recommend viewing/controlling your router via any app at all).
And, I'm pretty sure you agreed to allow it to do so, even if it is 'tracking' you (it's not on by default).
X’s
This is what game radar is about:
It isn't tracking you, it's for optimizing your access to game servers. You use it if and when you want to, it's passive relative to you otherwise.
I wouldnt care so much about it if it didnt display games I dont even play and outdated ones at that lol
But I guess if its of no consequence, it can stay and add to the hideous menus :D
Also 5 days and 6 hours uptime so far wooo since updating to this latest firmware, I think we got a keeper but I'd probably like to give it a week extra to be sure
Thank you for your quick response. I will try this out during the weekends.
Successfully upgraded to latest firmware from beta. Only did this - "Restart the computer you're using to perform the update with. Note that 'Restart' is not the same thing as 'Shutdown'." Thanks.
When a PC has been on for many days/weeks/months, it may get into a state where it seems to respond to input, but doesn't.
A Restart (not Shutdown, then just start up/power up), brings up the OS 'fresh', and it should be operating as expected then.
If you bring up Task Manager, you can see at the bottom the 'Up time'. In Days: Hours: Minutes: Seconds. If using the computer intensively for even a short time (a few hours), a reboot can often help the system feel faster (i.e. less latency) and work as expected.
ughhh just jinxed it, got a reboot after 20 some odd days
is this cause of concern or just is what it is?
wondering if its worth doing a hardware swap or not
I have like 9 days left to decide, but I have a feeling I get another unit and it will do same thing. Probably just some software quirks.
did have data share agreement in Admin->privacy on and revoked it, heard lots of related bloated services to that that can be unstable across fw for multiple models, but just parroting what I skimmed here
I've been running the 9.0.0.6.102.4256 beta on two GT-AX6000s since almost the day it was released. I've purposely rebooted my routers a few times because I was experimenting with settings that require a reboot, but its been 100% stable between the reboots. Current uptime is 21 days.
Still good uptime or get a reboot?
The new 3.0.0.6.102_21514 is buggy, I reverted back to 3.0.0.4.388.23285.
New firmware broke the router immediately after I updated firmware. I had to press WPS to recover. But every time I upload my previous setting it would brick again. I had to reset and setup the router again, and then the iPhone ASUS app cannot detect the router. I reverted back and it works fine now.
Would like to clarify what you did. When you flashed 3.0.0.6.102_21514, you then immediately restored your settings from 3.0.0.4.388.23285 and went on from there?
Just as an example, when I flashed from 3.0.0.4.388.23285 to 3.0.0.6.102_21514, I did a full factory reset using the "Administration" menu with the "extra reset" box checked. Then manually restored my settings. Since then, 3.0.0.6.102_21514 has worked perfectly for me. If this is what you did, then never mind *smile*, our home networks are apparently different.
I do agree, though, 3.0.0.4.388.23285 is one of the most stable firmware releases I've used, but getting a little long in the tooth *smile*.
I used ASUS iPhone app to update firmware to 21514, and it broke router immediately. I recover it several times, once I upload my saved settings after recovering, it would be flashing red light immediately. I had to manually setup again, and it works. Then I found that the iPhone app can no longer connect to router. I reinstalled the app and it cannot detect router.
I downgrade to 23285 and it works immediately, everything.
That's your error - uploading settings from a different version. Flash the new version, reset using the WPS button, then get the WiFi, internet ang gui password setup to get a stable system. Once up and connected you should rebuild all your other settings manually. Don't restore from a previous version.
Never need to do that for years.
Plus, even after doing that, iPhone still can not detect router.
