Release ASUS GT-BE98 Firmware version 3.0.0.6.102_36878 (2024/12/04)
Top of the line products from Asus are neglected
I waited like a year for an update for axe 16000
Wi-Fi guest networks are not working 100% and there is some stability problems on the wan side
I agree the router is great but it needs better support
I have 3 guest networks setup and all work perfectly. What is not working on the wan side?
See the first page of this topic you Will see the bug its not crítical
Its not 100% vs the older firmware, gets some dropouts its erratic, there is no problem only se need better support, if there keep this up it Will be like the axe 16000 a full year for fixing instability
Thread cleaned up. Keep it on topic, no personal attacks, and let the moderators do the moderating.
How many releases (firmware) were there for the BE98 PRO?
How many releases (firmware) were there for the BE98?
The be98 should have bit more they are the same except for the Wi-Fi bands diferente 2 X 6ghz on the pro and one on the no pro but the non pro is older
Be98 pro received
Security:
1.Enhanced input parameter handling techniques to improve data processing stability and system security.
2.Enhance system access control mechanisms.
Bug Fixes and Enhancements:
1. Enhanced Client Connection Stability.
2. WPA Encryption Settings Update. Added new configuration options for WPA encryption, including the option to select AES for improved client compatibility. This setting can be found under "Network > Main Network".
3. Improved AiMesh Backhaul Compatibility.
