BubbleOBill
Hi, I have a ASUS routers (AX58U) that does not have vlan support. I’m looking to isolate a video doorbell and some security cameras that are connected via ethernet cable to an unmanaged POE switch. This switch is connected to the ASUS router, which in turn is connected to the NBN box.
Ideally I would like to create two subnets: one for my home network and the other for the cameras. Then create firewall rules to isolate those subnets from each another. Looking at the ASUS manual it seems the firewall only allows white listing of IPs rather than block. The other option is the Network Services Filter which seems to only filter LAN to WAN data so it won’t filter LAN subnets.
Any help appreciated. Thanks
