Asus Merlin 388.2_2 speed test history not working
On firmware 388.1, I had a similar issue. Test servers did not appear, nor did the START option work.
The solution in my case, I just had to delete the files in the folder "OOKLA" (path: /jffs/.sys/OOKLA).
Yesterday I updated to version 388.2_2, and it still works fine.
Regarding CPU performance in the tests, I didn't notice any differences:
Router:
PC:
Safely remove all USB devices.
Administration, System (check the box).
Reboot the router two times in the next 10 minutes. Waiting 5 minutes between reboots.
Do not insert any previously used USB drives that were used for amtm or other scripts, before formatting them on a PC as NTFS.
After inserting the USB drive into the router, use amtm to format it as Ext4 with journaling enabled.
I suggest to use the biggest swap file option available.
If you follow the directions, it will format the JFFS partition. :)
Go to Administration, System, and check the box...
