Hi, wondered if anyone else is facing a problem with trying to add Dlink DCS-2670L to the network on AC86U or the AC68U. I've got both and have tried both Asus and Merlin firmware. When I use the DLink app to add the camera, under local mode it does not show any cameras. I was able to add it when I first had my AC68U and the cameras were visible in Local mode. I can't remember which firmware it was. Since upgrading to the 384.6 Merlin I then lost Local view. The same with the AC86u.
I tried going back a few firmware versions and also tried Asus firmware but still no luck. Weirdly enough, on the AC68U running latest merlin firmware 384.6, I can now go a little further (i.e. camera recognised during setup process, but later on stops and says 'timeout error').
I raised several tickets with DLink and they even replaced my camera but still no luck. They even tried at their end to replicate the issue but they'd not come across this problem. It works fine for them.
I then tried tethering on my phone and connecting the DLink Camera to it, as well as a second iPhone (the one used to run the Dlink setup app), and it worked immediately. Camera connects and sets up within seconds and I can see the cameras in Local view mode as well as remote view mode. This leads me to believe that the issue is with the router and perhaps something that I've not configured correctly or a bug.
On the AC86U, I've tried enabling UPNP (even changed internal to start from 1 and go to 65535), I switched off firewall, I disabled AIProtection completely, I even fiddled around with the NAT passthrough features. Nothing seems to work. Somehow the router seems to be blocking the cameras.
Any help will be greatly appreciated.
