Ddwrt forums don't spoon feed people. If you want use their firmware, you have sit your butt down and spend few hours researching and reading.
They are not mean or rude, they don't want to keep answering same questions that have been answered a thousand times. So use search function or Google it.
DD-WRT - site very confusing. Many places say different things about the same topic. Sooo many diffent versions/builds.
Tomato - dearth of documentation.
Merlin - tons of advice here; up to date information; no confusion; active, healful and polite programmer.
Guess which choice I made!
I am using AC68U. With my limited experience of DD-WRT and ASUSWRT Merlin on this router, Merlin's build offers much better performance on the USB storage. I consistently got more than 40MB/s transfer rates on Merlin's while <25MB/s on DD-WRT (wired connection). Wireless transfer (to/from USB storage) is also comparatively slower on DD-WRT. My ISP link is about 50Mb/s and I don't see much difference between DD-WRT and Merlin's on wired or wireless clients regarding internet speed. QoS is a bit shaky on both for me. The feature set of Merlin's is good enough for me and personally opt for Merlin's build for my AC68U.
I do not agree that the Broadcom drivers are the determining factor in LAN speeds. If it were only the drivers that affected wireless and LAN transfer speeds then all routers with the same chipset would have no performance difference and Tim Higgins would only have to test one router per chipset.
My direct experience indicates that there are many hardware and firmware factors that affect actual wireless radio performance. Depending on your definition of LAN, hardware and firmware also can have a significant role in the real world performance of the router.
Do you honestly think that a firmware can force a router perform faster beyond its hardware limitations?? I would love to see that.
Not all routers use same chipset. There is more to a router then just a chipset that makes up a router and dictates how a router will function and perform.
I am using ext2 on my USB Flash drive having been advised that the journal writes were a Bad Thing®.One big difference there is that Asuswrt uses a proprietary NTFS driver from Paragon, while DD-WRT uses the open-source driver, which is much slower. If you use ext3 on your USB HDD then the disk performance should be much closer between both firmwares.
KGB7,
I'm not sure if you are agreeing or disagreeing with my statements that disagreed with your post.
No, I do not believe that firmware can make hardware perform beyond its fundamental design capacity. I believe that the previous post which I quoted (by you, I believe) stated that the broadcom drivers were the determining factor in router performance for a given chipset. I disagreed with that and still do. The drivers do make a significant difference in terms of performance of a given chipset but, not the only factor. I stated that too.
I am aware that different routers use different chipsets. It is obvious that a router with a dual core 1GHz CPU has the capability to perform better than a router with a single core 800MHz CPU. Like any other computer, peripheral hardware such as ram and bus design can enhance or cripple the performance. Good drivers and firmware can allow the hardware to perform better but only to the limitations of all the component hardware combined. That is why I disagree with the post I was replying to which stated that Broadcom drivers were the determining factor of router performance.
From reading other posts in this string, it is apparent that some other open-source firmwares use different drivers than Broadcom; or, a combination of Broadcom drivers with others for different components of the router. This makes it even more true that the Broadcom drivers are not the sole determining factor in router performance.
Would ext3 be faster using your firmware? Would there be any better performance using a USB3 drive?
DrT
I bought yesterday an AC66U...but i have to return it as the range was worse than the stock cable tb router/modem (Hitron CVE 30360)....
Is this due to a firmware issue or may be due to a faulty device?
I've used all three.
DDWRT by Brainslayer is great and stable and is now provided commercially on select Buffalo routers. It has been at least a year since I used DDWRT but I really like the firmware and may buy a Buffalo just to have DDWRT on it.
Tomato is the best of the lot in terms of capability, features and performance primarily because of its robust QOS features which work great with their default settings and easy to configure.
Merlin is the best for a stable and very conservative firmware. For me the big letdown is the reluctance to upgrade the primitive QOS Asus supplies.
Merlin also has a big advantage in the way the firmware is provided with a logical and well-laid out download service. Everything is well organized, labeled, commented and the gentleman is busy in the forums. In short, very professional.
Tomato I just cannot grasp what is what and where in the download services and the slew of varying versions by different people make it attractive only to hobbyists with a lot of time on their hands.
So Merlin rules overall in my book!
I had been a long-time user of old WRT54GS router(s), and used a succession of 3rd party firmware on them for many years, using TomatoUSB for the last couple years. Just upgraded my home internet to 75 mb service, and that overran the capability of the trusty WRT54GS, so after a bit of research I purchased a new ASUS RT-AC68U.DD-WRT - site very confusing. Many places say different things about the same topic. Sooo many diffent versions/builds.
Welcome To SNBForums
