News ASUS Product Security Advisory - ASUS Router AiCloud vulnerability (01/02/2025)
bennor
Part of the Furniture
Asus posted a Product Security Advisory on Jan 2, 2025 for Asus router AiCloud vulnerability.
01/02/2025 ASUS Router AiCloud vulnerability
Injection and execution vulnerabilities in certain ASUS router firmware series that allow authenticated attackers to trigger command execution have been identified in ASUS router AiCloud. If the vulnerabilities are exploited, authenticated administrators could execute commands through the router over the network. We have released new firmware update for 3.0.0.4_386, 3.0.0.4_388, 3.0.0.6_102 series.
We advise you to check your equipment and security procedures regularly, as this will make you safer. As a user of an ASUS router, we recommend following these steps:
• Update your router with the newest firmware. We encourage you to do this when new firmware becomes available. You can find the newest firmware on the ASUS support page at
https://www.asus.com/support/ or the relevant product page at
https://www.asus.com/Networking/. ASUS has provided a link to new firmware for some routers at the end of this notice.
• Use different passwords for your wireless network and router-administration page. Use passwords that have at least 10 characters, with a mix of capital letters, numbers and symbols. Do not use the same password for more than one device or service.
If you are unable to update the firmware quickly or the router (with 3.0.0.4_382 firmware) is end-of-life , please ensure that both your login and WiFi passwords are strong. It is recommended to (1) Enable the password protection in AiCloud (2) disable any services that can be accessed from the internet, such as remote access from WAN, port forwarding, DDNS, VPN server, DMZ, port triggering, and FTP; and (3) use passwords that have more than 10 characters, including a mix of uppercase letters, numbers, and special characters to enhance the security of your devices. Do not use passwords with consecutive numbers or letters, such as 1234567890, abcdefghij, or qwertyuiop.
For further help with router setup and an introduction to network security, please visit
How to update the firmware of your router to the latest version?
https://www.asus.com/support/FAQ/1039292
FirmwareCVE
3.0.0.4_386 series
3.0.0.4_388 series
3.0.0.6_102 series
CVE-2024-12912
CVE-2024-13062
Is this a new exploit, or does this relate to the vulnerabilities already disclosed last month?
It is likely the same AiCloud exploit mentioned in earlier Asus product notices and firmware updates since last November.
Disclosing issues after the fix is a normal practice. No need to give pointers to hackers.
When I saw this post I figured it would confuse some people. And it has!
Another social media excess...
A few routers are still missing the AiCloud vulnerability fix
RT-AX89X - Qualcomm hardware, perhaps not affected
RT-AX52 - no USB port, no AiCloud
ZenWiFi XD6 - no USB port, no AiCloud
ZenWiFi XC5 - no USB port, no AiCloud
