Asus repeater reverts to 80mhz after losing station?
Even though I set and saved it ti only use 20mhz only before changing to repeater mode.
You still refuse to accept the fact Router wireless settings don't apply when you switch to Repeater mode. Your "fixing" attempts are chaotic setting changes. There is no "solution" to this "issue" and what you are trying to use this cheap AIO home router for may cost you a new drone.
Recommend me a repeater then
I've never seen a drone operator using repeater. I can only recommend you a drone with no connection issues in allowed range.
