Asus Rog Rapture GT6 doesnt save my changes
Jarvisit
Hello, I've been using the ROG Rapture GT6 Mesh wifi system for a while now and the settings I made are not saving. I am using the latest fw version on the site on both products. I couldn't find a beta version, and it doesn't support the Merlin system.
To better explain the problem of setting not registering:
Problems:
On both devices some of the settings are not saved. For example, if I remove the frequency of Wifi 5 GHz-2 band from automatic and save it to make it 108, the page refreshes and the old settings appear.
With the Intel BE200 WiFi 7 wifi card I get 400 mbps from about 30 cm (5 ghz-1 - channel 36).
I think the settings are not saved due to a problem with NVRAM, but there is also a signal problem. I get a very comfortable 1 Gbps wireless speed with the Huawei AX modem provided by Superonline.
My tries:
Both routers have been reset both from the interface and by hard reset method (WPS and Power key).
Both routers were tried separately as main devices.
They were connected via wifi and ethernet and set up via the interface.
Setup was also done with the mobile application.
Does anyone else have this problem or know the solution?
