Asus Router RT-AC88U VPNStable (all): 380.65 -- Error; check configuration
rt2016
Hi Guys,
I decided yesterday evening to upgrade my Asus router to AsusWrt Merlin (versionStable (all): 380.65).
The upgrade worked like a charm no hickup at all!
This morning I checked the VPN setup and find out that I can't activate VPN; error message
Warning: any unsaved change will be lost.
Error - check configuration!
Haven't had any problem so far with the former version 380.64_2, I use OpenVPN for the VPN setup and can see in the change log that the have been done significant changes.
Please have a look in attached log-file.
Right now I need some input, what I can do.
best regards
rt2016
  • AsusLog1.txt
If I update with that new release will I have issues with my 87U?
There's a problem specific to the RT-AC87U and wifi configuration in 380.65, and I haven't been able to track the source.
And the problem is....
Sometimes when making wifi settings changes an error message appears about the router being unable to determine the region. I don't know anything more than that.
thats not a big issue. I dont make changes regularly. If it doesnt drop connection and its stable I think I will update.
The wifi driver for the RT-AC87U wasn't changed, so stability should be the same as with 380.64.
