justinglock40
thank you did this. So I don’t need to do anything else. As far as configuration goes.1. Install script, through AMTM is the easiest.
2. Create a new policy (11), name it, identify which active VPN interface you want to use, select desired options.
3. Add domain (14), type in domain or subdomain, identify which policy you want it to use.
4. Repeat, ensuring you add as many domains as possible identified with the particular site/service. IPFoo Chrome extension can help identify these domains.
5. By default, policies will update every 15 minutes, pulling new IP addresses associated with the domains and respective policies. Particularly when starting a new policy, you may wish to use option 8 to manually update the policies several times to ensure you’re associating as many IPs as possible.
6. Enjoy.
Because I tried that before and when I’d run a trace route the traffic still routed normally
