Asus RT-86U blocked in Chinese language
@RMerlin : Okay, thank you for this info
@Martineau : OMG, thx, I didn't have eyes in front of the holes ...
So it works better; but nothing happens, I still have a choice only between English and Chinese.
It's not a big deal.
A huge thank you to you 2, and to those who also tried to help me. Have a good day
Choosing Chinese should use French, as @Martineau 's command overrides the Chinese dictionary file
@Martineau :
Did you issue both commands?
mount -o bind   /www/CN.dict   /www/FR.dict
and
service restart_httpd
EDIT: The limited menu choice of only two languages will not change, but the Chinese option will be replaced by French! together with all visible on screen text will change to the mapped dictionary file.
Nop, I change language but nothing change...
@Martineau : Yes, I try again now, the same thing; English is English, CN is CN, I signed out, changed my workstation, cleared the cache, nothing to do. It’s weird but it’s like that. there is no dead man, it remains usable and above all easier to understand in English than in Chinese :)
Just one last attempt please...my previous command reverts FR to CN
df
umount /www/FR.dict
umount /www/CN.dict
mount -o bind /www/FR.dict /www/CN.dict
df
and please post the output of each command
ASUSWRT-Merlin RT-AC86U 384.17_0 Sun Apr 26 02:28:53 UTC 2020
jeanno@RT-AC86U-2280:/tmp/home/root# df
Filesystem           1K-blocks      Used Available Use% Mounted on
ubi:rootfs_ubifs         79016     65400     13616  83% /
devtmpfs                220096         0    220096   0% /dev
tmpfs                   220208       456    219752   0% /var
tmpfs                   220208      1660    218548   1% /tmp/mnt
mtd:bootfs                4480      3356      1124  75% /bootfs
mtd:data                  8192       548      7644   7% /data
/dev/mtdblock8           49152      2680     46472   5% /jffs
ubi:rootfs_ubifs         79016     65400     13616  83% /www/CN.dict
ubi:rootfs_ubifs         79016     65400     13616  83% /www/FR.dict
jeanno@RT-AC86U-2280:/tmp/home/root# umount /www/FR.dict
jeanno@RT-AC86U-2280:/tmp/home/root# umount /www/CN.dict
jeanno@RT-AC86U-2280:/tmp/home/root# mount -o bind /www/FR.dict /www/CN.dict
jeanno@RT-AC86U-2280:/tmp/home/root# service restart_httpd
Done.
/dev/mtdblock8           49152      2704     46448   6% /jffs
Done.
OK, one last confirmation to display the contents of the mapped '/www/CN.dict' file
tail -n 20 /www/CN.dict
tail -n 20 /www/DE.dict
tail -n 20 /www/FR.dict
I suppose ASUS could have built the firmware with ALL (except Eglish EN.dict) language files containing Chinese, but perhaps mapping /www files is indeed physically impossible.
Big worries. I carried out the requested manipulation, and miraculously I had French: D
But, power outage, laborious restart and return to square one. So I took over the entire protocol as shown in the code.
And by switching from Chinese to French, it works :)
But I don't dare to restart the router
tmpfs                   220208       440    219768   0% /var
tmpfs                   220208      1828    218380   1% /tmp/mnt
mtd:data                  8192       596      7596   7% /data
/dev/mtdblock8           49152      2748     46404   6% /jffs
jeanno@RT-AC86U-2280:/tmp/home/root# ls -lah /www/*.dict
-rw-rw-r--    1 jeanno   root      187.6K Apr 26 06:10 /www/CN.dict
-rw-rw-r--    1 jeanno   root      199.9K Apr 26 06:10 /www/EN.dict
-rw-rw-r--    1 jeanno   root      240.4K Apr 26 06:10 /www/FR.dict
jeanno@RT-AC86U-2280:/tmp/home/root# mount -o bind   /www/CN.dict   /www/FR.dict
Done.
mtd:data                  8192       604      7588   7% /data
/dev/mtdblock8           49152      2752     46400   6% /jffs
umount: can't unmount /www/CN.dict: Invalid argument
Done.
tmpfs                   220208      1832    218376   1% /tmp/mnt
/dev/mtdblock8           49152      2744     46408   6% /jffs
jeanno@RT-AC86U-2280:/tmp/home/root# tail -n 20 /www/CN.dict
Événement
Le système détecte les événements suivants et déclenche différents effets LED.
En cas d’activation de Game Boost, vous pouvez voir la barre LED utiliser un effet de respiration rouge.
Compteur de trafic
La LED arc-en-ciel indique votre trafic en temps réel et change de combinaison de couleurs selon votre vitesse Internet actuelle.
Échec de la connexion
En cas d’échec de la connexion, vous pouvez voir la barre LED utiliser un effet de comète rouge.
Blocage d’attaque
Lorsque le système bloque avec succès une attaque potentielle, vous pouvez voir une barre LED utiliser un effet de comète rouge.
Remarque : Après avoir sélectionné Événement, le système affiche différents effets LED en fonction de l’événement actuellement détecté. Vous ne pouvez pas contrôler les LED de votre appareil pendant l’utilisation de cette fonction.
网易UU加速器
UU路由器插件为三大主机PS4、Switch、Xbox One提供加速。可实现多台主机同时加速,NAT类型All Open。畅享全球联机超快感!
Débit pouvant atteindre jusqu'à 2167 Mbps pour la bande des 5 GHz et 750 Mbps pour la bande des 2.4 GHz afin de garantir une excellente qualitié de lecture de contenu 4K et une expérience réseau fluide sur Playstation 4, Xbox One et PC.
Deux ports USB à haut débit et puissance dédiés au stockage réseau et à l'impression réseau multifonction.
Fonction AiProtection, optimisée par la technologie Trend Micro™ fournissant une solution de surveillance et de sécurité réseau en temps réel pour vous offrir une tranquillité d'esprit totale.
Performances de jeu et de telechargement supérieures et prise en charge de multiples connexions de clients.
Suivez les instructions suivantes pour utiliser un serveur VPN.<br>1. Activez le protocole VPN PPTP.<br>2. Entrez la plage d'adresses IP du client (30 clients maximum).<br>3. Entrez le nom d'utilisateur et le mot de passe du client VPN.<br>4. Ouvrez le programme de connexion VPN sur votre ordinateur ou appareil mobile.<br>5. Créez une nouvelle connexion VPN de type PPTP avec l'adresse de serveur
Le serveur VPN ne prend en charge qu'un maximum de 30 clients.
30 clients maximum
The function does not support [ WPA2-Enterprise, WPA-Auto-Enterprise ] security authentication method.
jeanno@RT-AC86U-2280:/tmp/home/root# tail -n 20 /www/DE.dict
Ereignis
Die folgenden Ereignisse werden vom System erkannt, woraufhin entsprechende LED-Effekte als Benachrichtigung ausgelöst werden.
Wenn Sie Game Boost verwenden, zeigt die LED-Leiste einen Atmungseffekt in Rot.
Datenverkehrsmessung
Über die Regenbogen-LED wird Datenverkehr in Echtzeit angezeigt. Dabei variiert die Farbkombination entsprechend der aktuellen Internetgeschwindigkeit.
Fehlgeschlagene Anmeldung
Wenn die Anmeldung fehlschlägt, zeigt die LED-Leiste einen Komet-Effekt in Rot.
Abwehr von Angriffen
Wenn das System einen potentiellen Angriff erfolgreich abwehrt, zeigt die LED-Leiste einen Komet-Effekt in Rot.
Hinweis: Sobald ein Ereignis ausgewählt wurde, zeigt das System verschiedene Beleuchtungseffekte auf Basis des aktuell erkannten Ereignisses. Bei Verwendung dieser Funktion können Sie Geräte-LEDs nicht steuern.
网易UU加速器
5 GHz Geschwindigkeit bis 2167 Mb/s und 2.4 GHz bis 750 Mb/s für 4K-Videowiedergabe und Unterbrechungsfreiheit bei PC, Xbox und PlayStation.
Zwei USB-Ports mit hoher Geschwindigkeit und hoher Stromversorgung zur Unterstützung von Netzwerkspeicher und Multifunktionsdrucker.
AiProtection mit Trend Micro™ -Echtzeitnetzwerküberwachung und Sicherheit für totale Sorglosigkeit.
Stromnutzung auf hohem Niveau für ausgezeichnete Download- und Gaming-Leistung und Mehrfach-Client-Vebrindungen.
Um den VPN-Server zu benutzen, folgen Sie bitte diesen Schritten.<br>(1) PPTP VPN-Server aktivieren<br>(2) IP-Bereich für Client-IP einstellen. (Maximal 30 Clients) <br>(3) benutzername und Kennwort für den VPN-Client einrichten.<br>(4) VPN-Verbindungsprogramm in Ihren Computer oder Smartphone öffnen.<br>(5) Eine neue PPTP VPN-Verbindung hinzufügen. Die VPN-Serveradresse lautet
VPN-Server erlaubt maximal 30 Clients!
Maximal 30 Clients
jeanno@RT-AC86U-2280:/tmp/home/root# tail -n 20 /www/FR.dict
Événement
Compteur de trafic
Blocage d’attaque
网易UU加速器
30 clients maximum
Yay!!! :):):) and it appears the language drop-down menu does reflect the current (hacked) two options! :D
P.S. Apologies for initially getting the mapping the wrong way round it's been a long time since I needed to use it myself.:oops::rolleyes:
P.P.S. Thanks for persisting and believing in me and my proposed solution.
OK, during the boot, you will need to automatically reapply the French language mapping using a script ….as per the instructions here Trying to change language from Japanese to English on ASUS RT-AC86U but obviously change 'EN.dict' to 'FR.dict'
Do not apologize, thanks to you and your determination I succeeded, and your method should appear in the FAQ.
If I understand the other topic correctly, I must type this:
echo -e "#!/bin/sh\nmount -o bind   /www/FR.dict   /www/\FR.dict\ndf\nservice restart_httpd\n" >/jffs/scripts/Dictionary_MSG.sh;chmod +x /jffs/scripts/Dictionary_MSG.sh
and
echo -e "#!/bin/sh\n/jffs/scripts/Dictionary_MSG.sh\n" >> /jffs/scripts/init-start;chmod +x /jffs/scripts/init-start
and
No typing required! :cool:
EDIT: Once you have corrected one of the duplicate FR.Dict references in the first command to CN.Dict:eek::eek::eek:
Simply triple-click (both) the code line(s), and copy'n'paste into the SSH session on the router.
Then when convenient, reboot and see if the router retains the GUI in French!
Ah, I made a mistake. It's better like that ?
echo -e "#!/bin/sh\nmount -o bind   /www/CN.dict   /www/\FR.dict\ndf\nservice restart_httpd\n" >/jffs/scripts/Dictionary_MSG.sh;chmod +x /jffs/scripts/Dictionary_MSG.sh
No, you want FR.dict to map over CN.dict
Yes, it's logical /D
So i've type
jeanno@RT-AC86U-2280:/tmp/home/root# echo -e "#!/bin/sh\nmount -o bind   /www/FR.dict   /www/\CN.dict\ndf\nservice restart_httpd\n" >/jffs/scripts/Dictionary_MSG.sh;chmod +x /jffs/scripts/Dictionary_MSG.sh
jeanno@RT-AC86U-2280:/tmp/home/root# echo -e "#!/bin/sh\n/jffs/scripts/Dictionary_MSG.sh\n" >> /jffs/scripts/init-start;chmod +x /jffs/scripts/init-start
I rebooted the router; this one stayed off, I had to press the button; once online, back from the interface in Chinese, I have to go back to English.
I must have made a mistake somewhere
So i've type
Can you please provide the output from these commands
cd /jffs/scripts
ls -lah Dict* init*
cat init-start
cat Dictionary_MSG.sh
@Martineau :
jeanno@RT-AC86U-2280:/tmp/home/root# cd /jffs/scripts
jeanno@RT-AC86U-2280:/jffs/scripts# ls -lah Dict* init*
-rwxrwxrwx    1 jeanno   root          81 May  1 18:22 Dictionary_MSG.sh
-rwxrwxrwx    1 jeanno   root          43 May  1 18:22 init-start
jeanno@RT-AC86U-2280:/jffs/scripts# cat init-start
#!/bin/sh
jeanno@RT-AC86U-2280:/jffs/scripts# cat Dictionary_MSG.sh
#!/bin/sh
df
@coxhaus : No idea
@Martineau :
#!/bin/sh
#!/bin/sh
df
@coxhaus : No idea
Do you see your typo?:rolleyes:
Try manually running the 'Dictionary_MSG.sh' script in the SSH console...
./Dictionary_MSG.sh
Sorry, I don't understand what mistake I made :(:confused:
jeanno@RT-AC86U-2280:/tmp/home/root# ./Dictionary_MSG.sh
-sh: ./Dictionary_MSG.sh: not found
Apologies, you need to be in the source directory where the script is located to use the shortcut path notation './'
cd /jffs/scripts
./Dictionary_MSG.sh
otherwise if you are in a different directory (say '/root') then you need to supply the full pathname of the script
