ASUS RT AC1900 Router w Netgear M1 issues
No worries, what did those commands give now? :)
Looks like it worked like a charm...what do I need to do to lock this in and maintain it.
nano /jffs/scripts/nat-start
#!/bin/sh
sleep 10
modprobe xt_HL
modprobe xt_hl
iptables -t mangle -A POSTROUTING -j TTL --ttl-set 65
chmod a+rx /jffs/scripts/*
These were the commands that I was given before to make them repeat but didnt work as well.
Well that's good news.
Now you need to do what you previously tried to do. Use the nano editor to create the file /jffs/scripts/nat-start
The contents of that file should look like this (don't worry about the missing sleep command, it's not needed):
#!/bin/sh
modprobe xt_HL
modprobe xt_hl
After you've saved the file and come out of the editor issue this command from putty:
Then log into the Asus' GUI and enable the option "Enable custom scripts and configs". After applying that change reboot the router.
Done.
Thank you very much. All of your help is very appreciated. If you ever need construction help HMU.
Is it still working after a reboot?
BTW My wife thinks constructing concrete buildings is a real job, rather than "messing about" with computers. :rolleyes:
Theyre all real jobs. Guys that do what you do keep guys that do what I do going.
On the subject of the connection. Upon following the process you set, my speeds dropped back below 1Mbps.
Hmm. Maybe the script didn't run or had an error in it.
Can you log onto the router with putty, enter the following commands and show us the output.
ls -l /jffs/scripts/nat-start
cat /jffs/scripts/nat-start
iptables -S -t mangle
Oh no. We're back to this problem. Your /jffs partition doesn't seem to be present. :mad:
Can you simply reboot the router and check it again please.
Rebooted and retried. Same result. Could this have been the same problem as before? Maybe i need to reflash wrt?
