Asus RT-AC3100/CA
skeal
Part of the Furniture
@RMerlin Can you tell me if asus-merlin supports the RT-AC3100/CA?
Couldn't find it on supported devices however the RT-AC3100 is supported by your firmware. Does this support include the CA version? Thanks I know you are busy!
/CA is probably just marketing speech for "this box contains bilingual instructions for Canada". This is just a normal RT-AC3100.
Thanks they are on sale right now. This is 4 port version does it matter?
Not really, just plug it to a switch if you need more ports.
Sent from my Nexus 5X using Tapatalk
