Hi LimJK,
Could you send feedback with system log, wifi by administration-> feedback? According to 5G2_DWB, we will discuss internally.
thanks.
Arthur,Hi LimJK,
thanks.
I have been running for almost 3 days with no known issues for now. All my mobile devices are Apple.
I like to set everything to factory reset DEFAULT to avoid chasing my own tail, due to changing NVRAM settings that I do not fully understand. The following are some of the things I modified all along since beta.
AiProtection : Set all settings to ON or Secured (except WPS is not disabled for AiMesh)
USB Application: All Disabled specifically Media Services & Servers; as I have a Synology NAS
Wireless : I left all as Default, apart from SSID / passphrase
LAN : DHCP with 40 manually assigned IPs, Link Aggregation LAN 1 & 2 for my Synology NAS
WAN : DDNS using Free Asus Services which is needed for my OpenVPN Server
IPV6 : Native
VPN : OpenVPN (change port 1194 to a high port number, RSA Encryption from 1024 to 2048 bit)
My only problem is I missed my Triband (considering that I have Wired Backhaul); which Arthur said they are discussing internally. I am curious if the passphrase of the 5GHz(2)_DWB channel is secured enough or as good as the current WPS implementation when searching for New AiMesh Node. Just a bit uncomfortable, that I have no control over the passphrase for this hidden channel.
Jim,Take a look at my post on my upgrade problem for FW 384.45149 for 3 RT-AC5300's. I had a big speed problem at the parent router which was sometimes as bad as no upload connectivity.
If you check your IOS speed near each node and then at the parent I'm curious if you observe the same speed loss at the parent with an IOS device? My testing was done using the OS app "Speedtest by Ookla"?
Jim,
I saw your postI can understand how you feel and certainly will missed the Triband for your 3 RT-AC5300
I did a "Speedtest by Ookla" test on my iPhoneXsMax, I have ensured that I am connected to my 5GHz(1) Band on my AiMesh Router by checking the BSSID. See my result (which I cannot complain), I believe you are aware that the key dependancy for the meaningfulness of the test result is the condition of the "Speedtest Server" available to you that you have chosen:
I usually run a test from my client to my NAS Server to test raw speed of my local network with another LAN Speed Test, I run it on my MacBookPro (Wireless 5GHz band). You can find it here: https://totusoft.com/lanspeed
The following is the result over gigabit Ethernet Connection
PS: I did factory Reset on all my ASUS AiMesh Router / Nodes.
Searching for dwb give me the clue:
In my GT-AC5300 there are 3 settings:
dwb_band=2
dwb_mode=1
dwb_scb=1
Overwriting it in the following order:
nvram set dwb_scb=
nvram set dwb_mode=
nvram set dwb_band=
nvram commit
Brings back the 2nd 5Ghz radio. It just pops-back to Smart Connect in my case.
So I'm back happy.
Although it's stupid the way Asus made this decision! I mean...there must be a product manager somewhere that really pays no attention and decides the features with no thoughts on what's out there.
And that's odd, because they do get our config every single time we send feedback. So they could run some comprehensive assessment what people are looking for and what config is actually running on their routers.
Late edit: sorry I couldn't revert sooner.
Pointless: those settings are not persistent. A reboot will turn them back on.
Still searching, but I'm afraid there's no fast way around, other than wait for Asus to allow us use the 2nd 5GHz radio![]()
Drabisan,
Suggestion: Arthur Lien mentioned that they are having internal discussion on this matter. May be it is not a good idea to mess around with these NVRAM. I will live with Dual band for now, hoping that Triband will be back soon.
Can anyone give a description of everything that this buys you? I hadn't seen this option in previous firmware versions under Administration -> System
Does it drop and reconnect your WAN connection when it can't get out to the Internet etc...?
Arthur,Hi LimJK,
thanks.
HuskyHerder,@LimJK
I don't know if it matters, but have you noticed that with the removal of the 5G-2 channel your 5300 will be running on a different set of channels vs the nodes?
For example my nodes are running on 157 and the router on 48.
I had always assumed the nodes and the router would match, in a perfect mesh system.
I get that the channel has been there all along. It just now seems more channel jumping vs the older way. Kinda curious if this is a bug from the recent decision to remove the 5g-2 channel.
Maybe I have missed a setting to fix the issue I am describing? Thoughts ? Maybe its just 0200 on Xmas day and my kids will be up in a few hours and I am not thinking clearly.![]()
Maybe your correct, this past week was the first time I ever took notice.HuskyHerder,
my AC5300 my 5G-(1) is on the lower 5GHz Band, and 5G-(2) has always been on the higher 5GHz Band.
Yup same here.I can see it on my WiFi Analyzer.
No argument there. All wired myself.Wishing that <MySSID>_DWB be removed and returning Triband back to those of us with Wired Backhaul.
I have held back upgrading my 2x 5300’s to this firmware having read this thread and the loss of the tri-band.
I also use wired backhaul so don’t want to lose a radio unnecessarily!
Aside from that, my high band 5G has much better range than my low band, so if the high band becomes the backhaul I’ll lose coverage!
Definitely hoping this becomes an option you can disable in the next release (and that the release is soon!).
Welcome To SNBForums
