and two 2.4GHz radios
So you want your router to occupy 66% of the whole spectrum on its own? Your neighbors would hate you
So you want your router to occupy 66% of the whole spectrum on its own? Your neighbors would hate you![]()
Who said anything about weeks? I finally have the ac87x platform working, stable & performing well. I see no reason to make any purchase in the near or mid-future, at least 12 months. By then who knows what the market will look like.As long as a customers budget allows for 'xxx' amount of dollars for 'yy' amount of hardware, the absolute dollar figure is not relevant to me.
What is relevant is how long the purchase lasts while delivering satisfactory performance for the customer.
I am still 'stuck' on an RT-N66U for personal use. But I could see myself spend $1,000 today for a router that embodied the full features of AC class WiFi that I read about so many years ago. (But I would also need to be satisfied that I would be using that same device in some capacity in 2020 too).
What I'm saying is that everything is relative. How much would you save on an 'open box' or 'refurbished' price in the next few weeks? Not enough for me to wait for if I wanted or needed the best router I can buy today.
(Why the next few weeks? Because by then, other products may be available and most certainly, the 'new' price will have fallen naturally too).
That's not a bad idea. Didn't think of that. Thanks.Not surprised that the Nest gave you some difficulties. If you really like Smart Connect, couldn't you just make a guest network to connect them and leave your private SSIDS all set the same? It's a little ironic that Google owns Nest and their OnHub will not even let you assign separate SSIDS to the band. Guest net worked like a charm for me on a different WiFi thermostat.
Sent from my SM-N920V using Tapatalk
Better than occupying 100 percent of the 5GHz spectrum with 2 AC class radios in much of the world![]()
5 GHz range barely leaves one's apartment. Its shorter range is a blessing in disguise, so once we get those fat 160 MHz channel, it won't bring the end of the (wireless) world upon us, thankfully... However, the 2.4 GHz range will easily interfere with any immediate neighbors.
Do you have your Asus RT-AC5300 yet RMerlin?
I don't have one, no.
My house must have paper for walls then because i can use my ipad at both neighbors houses and outside a few houses down with no disconnect using 5Ghz.![]()
You are also running a firmware with out-of-specs wifi limitations...
It has stayed connected so will leave it be for time being.
Man my transfer to my nas from surface pro 3 was night and day faster then previous routers. It's liking the nas so far. Great performance on that end.
Began playing around with the adaptive qos a bit tonight. Amazon Fire stick wasn't a fan of that feature. I'll check that out more in depth next few days but not encountering too many hiccups which given the beta retail nature of routers last few years, it's been surprising. Played a bit with the gaming boost and trend AV stuff, seemed like fluff at first glance.
Mine showed up! Wow this thing is huge. Its like a mini pc.
Are you referring to the build that John is using for the N66 ? Your statement makes it seem like i am breaking some kind of law.. That is certainly not my intention i assure you.![]()
The main reason why the output power is reduced in newer firmware is due to the fact they were initially transmitting at output levels beyond what was authorized by the FCC, and Netgear filed a formal complain. John's firmware still uses that older driver before the output power was reduced, and also enforces some power levels that are more in line with those in the EU region than in the US region. That's part of why you are seeing such a range with your router versus the rest of us.
For what it's worth, 'reliable' is probably a word I'd use for this router so far. No router comes without hiccups, Out of my 4 nest products, 1 of my nest cams is intermittently disconnecting because of the smart connect but beyond that, not really coming across much else.As nice as this looks, I'm picking up an AirPort Extreme tomorrow. Too much pain with the 87u. I'll keep checking back to see if this works as advertised. I do like the idea of smart connect and two 5 ghz for a bunch of busy wifi clients, but really just want reliability for now
Welcome To SNBForums
