I've never used the DDWRT before, how easy are they to use compared to Merlin?
The new DDWRT betas seem to be working well. Its unlocked all the wireless frequencies for me (in the UK) which means the 2nd 5GHz is no longer rubbish. Hurrah!
Did upgrading the firmware solve this or did you find another solution?@wsarahan Today, my 5GHz band 2 also hit the dreaded "Control channel undefined" bug. The only way I can work around it is to turn off Auto channel on the 2nd band. Seems like a failure to pick best channel or choosing an illegal channel (for my region) and bailing on it. Curious part is that devices actually still connect to it--horribly--but they still connect. Was your headset the only thing causing this? I noticed that my next door neighbor has messed with his access point (with way too high power levels) again, which could be the reason I am suddenly hitting this after 6 weeks of stable router bliss. Did manual channel setup solve your problem, or did you just have to get rid of the offending headset?
Upgrading firmware to 1355 fixed it for me, and it hasn't come back so far. Perhaps not coincidentally, I found that my son had purchased an ASTRO headset also when this happened. He experienced so much trouble with the headset that he returned it and everything was back to normal.Did upgrading the firmware solve this or did you find another solution?
Sent from my SM-N920V using Tapatalk
without reading through 32 paqges has anyone done any linkl aggregation testing with this yet as i just got on and have enabled bonding on the router and my synology ds 415+ and am still only seeing 100MB/s speeds max which i get over a single ethernet anyway , i have connected the 2 ethernet ports from the synology to ports 1 and 2 on the router and my test pc via lan 3 for testing
pete
lol it must have been late , i knew that just worded the post wrong , was wondering about a procedure to do it to give accurate and repeatable results![]()
Had nothing but a wonderful, stable experience with the latest MU-MIMO Alpha firmware.
This router is far and away the best out of box experience I've ever had and for the first time in forever I probably won't upgrade for sometime.
What is the brand and model of the USB 3 drive you are using?
What's the latest alpha fw version?
Tks
New Alpha firmware out - 2310.
https://www.asuswebstorage.com/navigate/s/5F8743D10A10466F916ABBB0298169C0Y
It finally allows you to change the wifi region under the professional tab
Welcome To SNBForums
