Asus RT-AC5300
raion969
Hello
Whats the best way to completly restore the Asus RT-AC5300 to default settings and also delet the completely nvram, so that the hole data is erased?
Administration - Restore/Save/Upload Setting : Tick the "Initialize all the settings.." box and then click Restore.
Nope just got a new Modem and i also wantet to reset all things.
Does it also delet all nvram settings/data?
I have not after the reset 83839/131072 bytes nvram usage is this normal?
If Colin's directions prove to not be enough, you can always go looking for @L&LD 's links to walk you through things.
maybe the new modem will help with your latency?
So far after teating and also my isp switched me frop post to ip internet.
I got from 103 dow to 112 and it is not even 24h online so no full syncron. And also Upload littlebit consistent.
Right now without any Settings, just default all, and also with Wifi enabled.
Is it useful to create more than 2gb of swap file?
I do not understand what you are saying. Try Google Translate.
No.
