I'm having some trouble getting my iMac to connect with various parts of my LAN via the AC56U. In particular, I'm having no luck getting it to communicate with my time machine connected to the router's USB3 port.
I'm using an iMac, the time machine is on a 1TB WD drive in a USB3 compatible housing. Its is formatted as Mac OS Extended (Journaled).
The first problem was getting the USB3 port to work at all. After reading another post on this forum, I disabled "Reducing USB3 interference" under the Professional tab of wireless settings. USB 3 then began functioning insofar as the relevant modem LED came on and I could see the drive in the UI and in the Mac Finder. I still couldnt access it though. After flashing with the Merlin FW, suddenly I was able to logon to both the USB3 (time machine) drive and to a separate drive in the USB2 port (containing dvd movies). That was progress of sorts, but I'm still having problems. This is mainly because I cant see any of the existing files on either drive. Though the UI can tell me how big the drives are, it also tells me they are both empty (ie, all space is available). However, it seems I can transfer data onto them via the Finder (at least with the USB2 drive - havent tried with the time machine as I dont want to screw up the existing data). More importantly, though, time machine cant see the drive attached to the Asus. I'd simply overwrite it if I could, but I cant configure it to backup.
Does anyone know how (or if) I can make the Asus see and backup with time machine?
