Current log with client comp - adaptive and lzo line added to custom...
I still see that I have
>>Provider push this, can be a problem.
Mar 20 11:37:03 openvpn[4811]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified (
rcvbuf 262144) this problem.
Any help to resolve this?
Mar 20 12:41:15 rc_service: httpd 430:notify_rc restart_vpnclient1
Mar 20 12:41:16 openvpn[1253]: event_wait : Interrupted system call (code=4)
Mar 20 12:41:16 openvpn[1253]: SIGTERM received, sending exit notification to peer
Mar 20 12:41:18 dnsmasq[1301]: exiting on receipt of SIGTERM
Mar 20 12:41:19 dnsmasq[1701]: started, version 2.76-g41a8d9e cachesize 1500
Mar 20 12:41:19 dnsmasq[1701]: warning: interface ppp1* does not currently exist
Mar 20 12:41:19 dnsmasq[1701]: asynchronous logging enabled, queue limit is 5 messages
Mar 20 12:41:19 dnsmasq-dhcp[1701]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 20 12:41:19 dnsmasq[1701]: read /etc/hosts - 5 addresses
Mar 20 12:41:19 dnsmasq[1701]: read /etc/hosts.dnsmasq - 11 addresses
Mar 20 12:41:19 dnsmasq-dhcp[1701]: read /etc/ethers - 14 addresses
Mar 20 12:41:19 dnsmasq[1701]: using nameserver 31.55.186.70#53
Mar 20 12:41:19 dnsmasq[1701]: using nameserver 31.55.185.46#53
Mar 20 12:41:19 kernel: tun: Universal TUN/TAP device driver, 1.6
Mar 20 12:41:19 kernel: tun: (C) 1999-2004 Max Krasnyansky <
maxk@qualcomm.com>
Mar 20 12:41:19 openvpn[1710]: OpenVPN 2.3.8 arm-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [EPOLL] [MH] [IPv6] built on Dec 24 2015
Mar 20 12:41:19 openvpn[1710]: library versions: OpenSSL 1.0.2e 3 Dec 2015, LZO 2.08
Mar 20 12:41:19 openvpn[1711]: NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Mar 20 12:41:19 openvpn[1711]: Socket Buffers: R=[122880->131072] S=[122880->131072]
Mar 20 12:41:19 openvpn[1711]: UDPv4 link local: [undef]
Mar 20 12:41:19 openvpn[1711]: UDPv4 link remote: [AF_INET]81.171.75.11:1194
Mar 20 12:41:19 openvpn[1711]: TLS: Initial packet from [AF_INET]81.171.75.11:1194, sid=d8189f2e 6e75ed0d
Mar 20 12:41:20 openvpn[1711]: VERIFY OK: depth=1, C=US, ST=VPN, L=VPN, O=VPN, OU=VPN, CN=VPN, name=VPN, emailAddress=VPN
Mar 20 12:41:20 openvpn[1711]: Validating certificate key usage
Mar 20 12:41:20 openvpn[1711]: ++ Certificate has key usage 00a0, expects 00a0
Mar 20 12:41:20 openvpn[1711]: VERIFY KU OK
Mar 20 12:41:20 openvpn[1711]: Validating certificate extended key usage
Mar 20 12:41:20 openvpn[1711]: ++ Certificate has EKU (str) TLS Web Server Authentication, expects TLS Web Server Authentication
Mar 20 12:41:20 openvpn[1711]: VERIFY EKU OK
Mar 20 12:41:20 openvpn[1711]: VERIFY OK: depth=0, C=US, ST=VPN, L=VPN, O=VPN, OU=VPN, CN=vpn, name=VPN
Mar 20 12:41:20 openvpn[1711]: Data Channel Encrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 20 12:41:20 openvpn[1711]: Data Channel Encrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mar 20 12:41:20 openvpn[1711]: Data Channel Decrypt: Cipher 'AES-256-CBC' initialized with 256 bit key
Mar 20 12:41:20 openvpn[1711]: Data Channel Decrypt: Using 256 bit message hash 'SHA256' for HMAC authentication
Mar 20 12:41:20 openvpn[1711]: Control Channel: TLSv1.2, cipher TLSv1/SSLv3 DHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Mar 20 12:41:20 openvpn[1711]: [vpn] Peer Connection Initiated with [AF_INET]81.171.75.11:1194
Mar 20 12:41:22 openvpn[1711]: SENT CONTROL [vpn]: 'PUSH_REQUEST' (status=1)
Mar 20 12:41:22 openvpn[1711]: PUSH: Received control message: 'PUSH_REPLY,redirect-gateway def1 bypass-dhcp,dhcp-option DNS 198.18.0.1,dhcp-option DNS 198.18.0.2,rcvbuf 262144,explicit-exit-notify 5,route-gateway 172.21.90.1,topology subnet,ping 20,ping-restart 40,ifconfig 172.21.90.4 255.255.254.0'
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: timers and/or timeouts modified
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: explicit notify parm(s) modified
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: --sndbuf/--rcvbuf options modified
Mar 20 12:41:22 openvpn[1711]: Socket Buffers: R=[131072->245760] S=[131072->131072]
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: --ifconfig/up options modified
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: route options modified
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: route-related options modified
Mar 20 12:41:22 openvpn[1711]: OPTIONS IMPORT: --ip-win32 and/or --dhcp-option options modified
Mar 20 12:41:22 openvpn[1711]: TUN/TAP device tun11 opened
Mar 20 12:41:22 openvpn[1711]: TUN/TAP TX queue length set to 100
Mar 20 12:41:22 openvpn[1711]: do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Mar 20 12:41:22 openvpn[1711]: /usr/sbin/ip link set dev tun11 up mtu 1500
Mar 20 12:41:22 openvpn[1711]: /usr/sbin/ip addr add dev tun11 172.21.90.4/23 broadcast 172.21.91.255
Mar 20 12:41:22 openvpn[1711]: updown.sh tun11 1500 1570 172.21.90.4 255.255.254.0 init
Mar 20 12:41:23 rc_service: service 1753:notify_rc updateresolv
Mar 20 12:41:23 dnsmasq[1701]: exiting on receipt of SIGTERM
Mar 20 12:41:23 dnsmasq[1759]: started, version 2.76-g41a8d9e cachesize 1500
Mar 20 12:41:23 dnsmasq[1759]: warning: interface ppp1* does not currently exist
Mar 20 12:41:23 dnsmasq[1759]: asynchronous logging enabled, queue limit is 5 messages
Mar 20 12:41:23 dnsmasq-dhcp[1759]: DHCP, IP range 192.168.1.2 -- 192.168.1.254, lease time 1d
Mar 20 12:41:24 dnsmasq[1759]: read /etc/hosts - 5 addresses
Mar 20 12:41:24 dnsmasq[1759]: read /etc/hosts.dnsmasq - 11 addresses
Mar 20 12:41:24 dnsmasq-dhcp[1759]: read /etc/ethers - 14 addresses
Mar 20 12:41:24 dnsmasq[1759]: using nameserver 198.18.0.1#53
Mar 20 12:41:24 dnsmasq[1759]: using nameserver 198.18.0.2#53
Mar 20 12:41:24 dnsmasq[1759]: using nameserver 31.55.186.70#53
Mar 20 12:41:24 dnsmasq[1759]: using nameserver 31.55.185.46#53
Mar 20 12:41:25 openvpn[1711]: Ignore conflicted routing rule: 81.171.75.11 255.255.255.255
Mar 20 12:41:25 openvpn[1711]: /usr/sbin/ip route add 0.0.0.0/1 via 172.21.90.1
Mar 20 12:41:25 openvpn[1711]: /usr/sbin/ip route add 128.0.0.0/1 via 172.21.90.1
Mar 20 12:41:26 openvpn-routing: Configuring policy rules for client 1
Mar 20 12:41:26 openvpn-routing: Creating VPN routing table
Mar 20 12:41:26 openvpn-routing: Removing route for 0.0.0.0/1 to tun11 from routing tables
Mar 20 12:41:26 openvpn-routing: Removing route for 128.0.0.0/1 to tun11 from routing tables
Mar 20 12:41:26 openvpn-routing: Removing rule 1001 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1002 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1003 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1004 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1005 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1006 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1007 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1008 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1009 from routing policy
Mar 20 12:41:26 openvpn-routing: Removing rule 1010 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1011 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1101 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1102 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1103 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1104 from routing policy
Mar 20 12:41:27 openvpn-routing: Removing rule 1105 from routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.1 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.2 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.204 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.56 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.73 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.133 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.191 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.205 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.211 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.250 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:27 openvpn-routing: Added 192.168.1.12 to 0.0.0.0 through WAN to routing policy
Mar 20 12:41:28 openvpn-routing: Added 192.168.1.121 to 0.0.0.0 through VPN to routing policy
Mar 20 12:41:28 openvpn-routing: Added 192.168.1.122 to 0.0.0.0 through VPN to routing policy
Mar 20 12:41:28 openvpn-routing: Added 192.168.1.123 to 0.0.0.0 through VPN to routing policy
Mar 20 12:41:28 openvpn-routing: Added 192.168.1.124 to 0.0.0.0 through VPN to routing policy
Mar 20 12:41:28 openvpn-routing: Added 192.168.1.218 to 0.0.0.0 through VPN to routing policy
Mar 20 12:41:28 openvpn-routing: Completed routing policy configuration
Mar 20 12:41:28 openvpn[1711]: Initialization Sequence Completed
